HELP!! No steering return cant figure this out
Old Sep 24, 2008 | 07:55 PM
teamteal91's Avatar
Default HELP!! No steering return cant figure this out
I have a 91 hatch with a B18 swap etc. I just recently replaced my front ball joints and upper control arms. Now I have no steering return, example- i can go down the road turn my wheel right and the car will stay going right. I figured maybe the new upper control arms were wrong throwing of the caster or something i checked and they are identical to the stock ones i removed. I am pretty sure i didnt have this problem before i replaced these parts although i only drove the car for a few days after the swap before replacing them but i think i would have noticed, if anyone has experieced this or has any ideas please help i am lost and this is dangerous and annoying.
Old Sep 25, 2008 | 07:00 PM
teamteal91's Avatar
Default Re: HELP!! No steering return cant figure this out (teamteal91)
Anybody?? any ideas at all, could i have a bad manual steering rack im very confused. please help
Old Sep 25, 2008 | 07:04 PM
Crx Jimmy's Avatar
did you put the arms on the wrong sides?
Old Sep 25, 2008 | 08:01 PM
91civiccross's Avatar
Default Re: HELP!! No steering return cant figure this out (Crx Jimmy)
Did you get an alignment? If not, get one.
Old Sep 25, 2008 | 08:04 PM
crxcorey's Avatar
I'd have to go with crx jimmy. the steering rack just couldn't go bad that quick
Old Sep 26, 2008 | 07:12 AM
teamteal91's Avatar
Default Re: (crxcorey)
I definatley put them in on the correct sides they were stamped left and right also i double and triple checked, i have not got an alignment tho, i am doing that tomorow, so well see what they tell me maybe my toe is so far off its throwing it all outa wack , my tires do screech like dying cat around even light turns.
Old Sep 26, 2008 | 10:13 AM
efjones9's Avatar
Default Re: (teamteal91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civiccross &raquo;</TD></TR><TR><TD CLASS="quote">Did you get an alignment? If not, get one. </TD></TR></TABLE>
i agree might be a caster prob. not sure tho
Old Sep 26, 2008 | 07:20 PM
teamteal91's Avatar
Default Re: (efjones9)
if it is a caster issue how would i adjust it - the front radius arms?
Old Sep 26, 2008 | 07:29 PM
dacrxguy's Avatar
caster cant be adjusted only toe cant by turning your tie rod in front the thing that is throwing your caster off is the uper control arm
Old Sep 27, 2008 | 08:14 AM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamteal91 &raquo;</TD></TR><TR><TD CLASS="quote">I definatley put them in on the correct sides they were stamped left and right also i double and triple checked,</TD></TR></TABLE>
Maybe they were stamped R and L but remember r and l is when sitting in the car, not looking at it from the front. people screw that up all the time. some make sure the L is on the driver side and the R is on the passenger side
Old Sep 27, 2008 | 09:48 AM
Tyson's Avatar
get an alignment, bring back some numbers, b4 and after and let us know.
Old Sep 27, 2008 | 10:37 AM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamteal91 &raquo;</TD></TR><TR><TD CLASS="quote"> Now I have no steering return, example- i can go down the road turn my wheel right and the car will stay going right. </TD></TR></TABLE>
Can you describe that a bit clearer? Is it pulling to the right when you let go of the wheel, or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">get an alignment, bring back some numbers, b4 and after and let us know.</TD></TR></TABLE>
Old Sep 27, 2008 | 04:50 PM
gearhead16's Avatar
Default Re: HELP!! No steering return cant figure this out (grog)
how did you install the ball joints my friend put his in with a ball pein hammer and dented the top of them and his did the same thing he said after driving it awhile its getting alittle better
Drop_A_Dookie
12
Feb 13, 2011 07:56 PM
georgeseq
Feb 15, 2008 06:59 PM
Yellowone
Apr 6, 2006 05:30 PM
LSV_REX
Mar 31, 2006 12:36 PM
