From Maunual to Power Steering swap 97 Hatch
Old Sep 24, 2008 | 04:30 PM
JMcDB18C's Avatar
Default From Maunual to Power Steering swap 97 Hatch
Hey guys I just need a little bit of help. I been out the game for a little while after I sold my Type R and I just picked up a 97 Civic Hatch and it dosent have power steering. If I am correct I can just buy a Steering rack and replace mine with a power steering one and just install the pump, bracket, and lines and everything should be ok....correct? Any feedback would be nice...thanks
Jon
Old Sep 24, 2008 | 04:34 PM
geebs's Avatar
Default Re: From Maunual to Power Steering swap 97 Hatch (JMcDB18C)
Yeah thats pretty much it..
Theres a power steering pressure sensor on one line, and you'll have to wire that to the ECU..
Old Sep 24, 2008 | 04:45 PM
JMcDB18C's Avatar
Hmmmmmm.....Ok thanks man
Old Sep 24, 2008 | 05:47 PM
RyanA's Avatar
Default Re: (JMcDB18C)
As long as you don't drive around and regularly hold the steering wheel at full lock, you don't really NEED the sensor. It basically idles the engine up when there is higher pressure in the system.
Yes, to be completely correct you could add the sensor and wiring into the picture. To just get up and going, rack, hoses, PS pump and brackets.
Old Sep 25, 2008 | 07:12 PM
geebs's Avatar
Default Re: (RyanA)
9 outta 10 times if you go to a junkyard for the ps lines, pump, brackets, etc.. you'll get the sensor.. and yes, its not required. its only for the higher pressures when you lock the wheel in a direction..
Old Sep 27, 2008 | 12:03 PM
B20inDCinLBC's Avatar
anybody knows how much the entire power steering setup averages for? tks
Old Sep 27, 2008 | 05:46 PM
RyanA's Avatar
Default Re: (B20inDCinLBC)
Pick n Pull you can probably get it all for under 100. Regular salvage yard probably 150-350 depending on where you are. You may want to look on Ebay to see if you can find anything there.
Old Sep 27, 2008 | 09:36 PM
Davus's Avatar
Heads up, I am not sure if this is true or not, but if the power rack you get doesn't have the manual knuckle that attaches to the steering column, it may not fit. I am unsure if this is just a rumour, but the individual I purchased a manual rack from (I'm doing the opposite of you. :-) Need a power knuckle if true?) included one at a little extra cost.
If they are the same, eh. I have a new knuckle for sale. If different, good. Crisis averted.
clewis152
Aug 7, 2012 05:01 PM
Fred Demara
Jan 4, 2012 04:33 AM
dkdevil28
10
Oct 23, 2010 06:28 PM
DC-2guy
May 6, 2009 09:04 PM
Bradsxx7
Apr 12, 2009 02:36 PM
