94 Accord steering issues (not power steering)
Old Sep 24, 2008 | 09:44 AM
CyMule's Avatar
Default 94 Accord steering issues (not power steering)
I just finished replacing the brakes and rotors on my 94 Accord Ex (two door). (If you have done the front rotors, you understand the issues I ran into trying to switch them out ) I got everything put back together and have been driving with smooth braking! However, my steering is a little stiffer than before. Before I did the job, if I turned the corner I could let go of the steering wheel and the car would correct itself. Now, if I turn a corner the car only goes back to 5 degrees off of straight and it is a little stiff to get it straight. I haven't had the alignment checked, but the car isn't pulling either direction when driving or braking. I am wondering if something didn't get bolted up tight but wanted to see if anyone has any ideas what is causing the problem before I tear everything open again. There is no whining and I don't have a power steering loss, it just feels like something is rubbing in/on the steering knuckle or hub joint.
I did have to replace the lower ball joints when I did the front rotors because I destroyed the old ones trying to get them out, but I don't think this should affect that. The boots on the tie rod need replaced but they are in the same condition they were before I replaced the rotors.
Thanks for any help!
Old Sep 24, 2008 | 11:06 AM
TheMuffinMan's Avatar
He knows where you live!
I would get an alignment first. Then trouble shoot more. It's possible debris got into the power steering rack or it lost some lubrication.
relunner4th
Jan 20, 2018 12:28 PM
Ventolin
May 14, 2008 11:45 AM
Simple SOHC
Dec 18, 2003 04:40 AM
SOHCMAN
Nov 16, 2002 02:53 AM
