car wont start sometimes???
Old Sep 24, 2008 | 09:27 AM
BoBo Racing's Avatar
Default car wont start sometimes???
k like the title says car wont start sometimes dont know y ill turn the the key in the ingnition and all the lights turn on fuel pump priming and i go to crank the car and nothing no clicking soungs nothing do it a couple of times and same thing i walked away from the car came back 30 min lata put the key in the ignition and it started up like nothing it does this to me a couple of times dont know y does any one have any ideas
ps yea i know grammer sucks right now but need to fix it asap car is stuck again
Old Sep 24, 2008 | 09:31 AM
Default Re: car wont start sometimes??? (BoBo Racing)
how do i know if its the starter or a bad ignition idk just throwing out the idea
Old Sep 24, 2008 | 11:20 AM
Dave_B's Avatar
When it's running... bring that bish up to Orlando, we'll get it figured out.
Could be clutch switch or relay... you say no clicks, but lights on right?
Old Sep 24, 2008 | 11:36 AM
Default Re: (Dave_B)
yea no clicks but all the lights are on and i got rid of the clutch switch long time ago and if the car is running good ill be up there this weekend with the car so ill hit u up def
Old Sep 24, 2008 | 11:39 AM
Dave_B's Avatar
LMK d00d. I'll be here all weekend.
Old Sep 24, 2008 | 12:19 PM
yo dave u wont believe this now i changed my shift cables finally took the car for a test drive and now im blowing the ecu fuse every 5 min idk im looking around the engine harness trying to find where its catching ground idk man i hate this fix one problem and get another one need some ideas
Old Sep 24, 2008 | 01:16 PM
Default Re: (BoBo Racing)
found out y i was blowing the fuse now o2 senor wire melted on header and grounded it out so fix that problem and now just need to figure out y it starts when ever it wants well ill be going to orlando this weekend
Old Sep 24, 2008 | 01:24 PM
DontBlink's Avatar
check the main relay.
Old Sep 24, 2008 | 01:35 PM
Default Re: (DontBlink)
yea but if it was the main relay ......to my understaing the car wouldnt start at all if the relay is bad........the car starts up. it just takes awhile sometimes
Old Sep 24, 2008 | 01:49 PM
len's Avatar
len
Not a main relay.
I think clutch pedal switch or electrical portion of ignition switch.
toeKNEEohh
Jan 19, 2012 10:38 AM
ixbatmanxi
Mar 30, 2009 09:28 PM
03K24A4EX
May 26, 2006 04:47 AM
strappdatshyt
May 11, 2004 08:16 AM
cr-x si
Feb 27, 2003 06:26 PM
