No Fuel getting to the motor.
Old Sep 23, 2008 | 07:58 PM
dreadhead89's Avatar
Default No Fuel getting to the motor.
Ok This all started when I was delivering a couple of months ago. I left my car outside running when i came out and pulled out it bogged like it was out of gas( was really low thats were i was headed) any ways I kept trying to start it, a couple of times it fired but sounded like it wasnt getting enough gas. then after setting there it fired up like nothing was wrong and drove 2 more blocks were it died for the last time. thinking it was out of gas, put more in nothing. so I took the fuel line off tryed it thinking the fuel pump, and just a trickle of gas, so i think fuel pump. replaced fuel pump(unless there is anyway to hook them up wrong should be right) nothing. so I read around and people say main relay replaced it still know fuel. I just did a d15b swap and a ish tone of stuff so its KILLING me not having the car. So if anyone can help would be much obliged. Im Going crazy !
Old Sep 23, 2008 | 08:00 PM
sleepingciv's Avatar
Default Re: No Fuel getting to the motor. (dreadhead89)
when you run outta gas like you did you run the risk of getting naasty stuff sucked up the pump very tiny little things. Have you changed the fuel filter yet?
Can you hear the pump turn on?
Old Sep 23, 2008 | 11:40 PM
crazzymad's Avatar
Default Re: No Fuel getting to the motor. (sleepingciv)
ive got the same problem and i have changed the filter by the way how many filters are rhere and could it be the fuel line
Old Sep 24, 2008 | 03:30 AM
Default Re: No Fuel getting to the motor. (crazzymad)
Yeah i replaced everything when i did the pump. Still no power. Bout a new main relay still know power.
Old Dec 26, 2008 | 03:32 PM
ThatsMyEG's Avatar
Did you fix the problem if so let me know. im having this exact same problem somebody help.. thanks
Old Dec 26, 2008 | 05:20 PM
DOHCED8's Avatar
mine did that.. ended up being the pump.. try the fpr
Old Dec 26, 2008 | 09:14 PM
midwest aaron's Avatar
do you have power to the relay? do you have power to the pump? check your ground? check continuity through the fuel pump relay.
91cb7h23
Feb 10, 2013 04:13 PM
EF8 D-UNIT
Mar 16, 2006 04:49 PM
IAteg
Nov 11, 2005 12:34 PM
extreme90civic
Aug 29, 2005 06:45 PM
Propulsion
Jul 8, 2002 11:15 AM
