Problem with motor it's dies randomly
Old Sep 23, 2008 | 05:44 PM
redcivic13's Avatar
Default Problem with motor it's dies randomly
Well I have a GSR that randomly dies on me.
When I would be driving and then stop and then go back into first it just dies or sometimes it would die while i'm driving. Then when i would try and start it, it doesn't want to start up not until after 5 min. I recently changed the fuel filter and did a full tune up thinking that it would help but i guess it didn't.. please help me
Old Sep 24, 2008 | 03:27 AM
redcivic13's Avatar
bump
Old Sep 24, 2008 | 04:41 AM
jdmland's Avatar
Default Re: (redcivic13)
main relay starting to go
Old Sep 24, 2008 | 07:28 AM
redcivic13's Avatar
Default Re: (jdmland)
How would I be able to check if it's my main relay? And where is the main relay located?
Old Sep 24, 2008 | 07:43 AM
00GsR-TeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland &raquo;</TD></TR><TR><TD CLASS="quote">main relay starting to go</TD></TR></TABLE>
a relay just doesnt start to go, its either working or not. A relay doesnt make its own mind up and say hey i want to click over or no i dont want to click.
check next time this happens to see if you have fuel pressure and spark while its "dead".
Old Sep 24, 2008 | 09:17 AM
System Lord's Avatar
Default Re: Problem with motor it's dies randomly (redcivic13)
Take the coil out of the distributor take it to local parts store & have them run an ohm check on it, they'll tell you what you need to know.
Old Sep 24, 2008 | 10:47 AM
jdmland's Avatar
Default Re: (00GsR-TeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00GsR-TeG &raquo;</TD></TR><TR><TD CLASS="quote">
check next time this happens to see if you have fuel pressure and spark while its "dead".</TD></TR></TABLE>
Maybe u should research main relay. NOOB
http://techauto.tripod.com/mainrelay.htm
Old Sep 25, 2008 | 03:40 AM
00GsR-TeG's Avatar
http://techauto.tripod.com/mainrelay.htm</TD></TR></TABLE>
or maybe your the noob? Honestly what make a relay just "start to go bad", it either has burnt up contact points on the board causing it NOT TO WORK, or the actual relay coil is burnt up and overheated causing it NOT TO WORK those are about the only reasons relays die. I mean all the parts inside of there have a set resistance its either that resistance or no resistance meaning the parts good or not good.
So where in there can a relay "start to go bad"?? Im just curious to here your logic. So there is no need for you to be an ******* and try flamming someone for something that you dont even understand.
Time for your lesson, do some reading and hopefully you will have a better understanding on how a relay works.
http://www.tegger.com/hondafaq....html
Modified by 00GsR-TeG at 7:46 AM 9/25/2008
Old Sep 25, 2008 | 12:16 PM
jdmland's Avatar
Modified by 00GsR-TeG at 7:46 AM 9/25/2008</TD></TR></TABLE>
I see somebody didn't read the first sentence in the link i provided, i'm done with this noob.
Old Sep 25, 2008 | 06:32 PM
redcivic13's Avatar
anyways lol
i just removed the main relay and took it apart to find that some of the joints were badly soldered so i resoldered them
and it works! thanks everyone
Old Sep 29, 2008 | 10:17 AM
00GsR-TeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcivic13 &raquo;</TD></TR><TR><TD CLASS="quote">anyways lol
and it works! thanks everyone</TD></TR></TABLE>
wow what do ya know burnt up contact points in a relay causing it not to work, would of never guessed . Glad you found the problem.
Old Sep 29, 2008 | 08:50 PM
vietnamezerice's Avatar
mine randomly dies but starts right up... does that sound like the main relay going bad?
H22Ej1
Jun 14, 2007 09:30 PM
og asr
Oct 1, 2005 12:14 AM
DirtyBirdJR
Aug 29, 2005 02:59 PM
triple_s1x
Feb 27, 2005 11:10 AM
1stealthls
Jul 30, 2002 06:36 PM
