Dangit, did I ruin my piston?
Is this piston ruined? Could I raise it up and smooth it out again with a punch or grinder? The offending valve has been replaced, but I did not put the head on yet.
i would tape off the entire top section of the top end leave your self some sanding room and use various sanding paper to smooth it back out DO NOT USE A PUNCH OR A GRINDER lol you can crack it or make it worse, just sand it back out smooth and use a shop vac at the same to suck up stuff as you work
well it was not running when it happened. I did this turning the crank by hand. I've sanded it down pretty well and it looks almost good as new. I'll post pics once its cleaned up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">I did this turning the crank by hand.</TD></TR></TABLE>
OMG........ How the hell did you manage to do that by hand?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv »</TD></TR><TR><TD CLASS="quote">i would tape off the entire top section of the top end leave your self some sanding room and use various sanding paper to smooth it back out DO NOT USE A PUNCH OR A GRINDER lol you can crack it or make it worse, just sand it back out smooth and use a shop vac at the same to suck up stuff as you work</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv »</TD></TR><TR><TD CLASS="quote">LOl nice man i guess you learned your lesson if it dont turn dont force it with a impact gun lol
Seems all fine now... Another lesson: dont work too late and in a rush to finish, that's when dumb mistakes happen.
</TD></TR></TABLE>Seems all fine now... Another lesson: dont work too late and in a rush to finish, that's when dumb mistakes happen.
Short Round
Jan 7, 2004 05:15 AM
