Spiratic IDOLING????
Old Sep 23, 2008 | 04:38 PM
cor4ey's Avatar
Default Spiratic IDOLING????
So i had a motor swap into my 91 crx from a d15 to a d16z6 ive had the car for a long time the motors been swapped for bout 3 years and i've had the motor rebuilt recently and its ran fine for about the last year all the sudden the other day i had it start over heating but it never got more than 3/4 and it was up hill then downhill was fine i filled it up with water it ran fine then today i started it up and it has a spiratic idoling any advice on what this might be? bad head gasket maybe?
Old Sep 23, 2008 | 05:38 PM
cor4ey's Avatar
bump
Old Sep 23, 2008 | 07:08 PM
reznunt's Avatar
Default Re: Spiratic IDOLING???? (cor4ey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cor4ey &raquo;</TD></TR><TR><TD CLASS="quote">spiratic idoling</TD></TR></TABLE>
are you talking about SPORADIC IDLING?
Old Sep 23, 2008 | 07:25 PM
D16SiHatch's Avatar
Default Re: Spiratic IDOLING???? (reznunt)
nope. pretty sure he's referring to this
Old Sep 23, 2008 | 07:37 PM
wasabivtec's Avatar
Default Re: Spiratic IDOLING???? (D16SiHatch)
I would have to lean towards a head gasket.
Old Sep 23, 2008 | 08:23 PM
crxfreak1117's Avatar
Default Re: Spiratic IDOLING???? (wasabivtec)
headgasket???????
i wouldnt say so clean your iacv (idle air control valve) on the back of your intake manifold.. thats if your talkin about your idle is jumpin up and down
are you still having overheating problems?
Old Sep 23, 2008 | 09:02 PM
crxsirg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">nope. pretty sure he's referring to this
...ha ha ha...that cracks me up
Old Sep 23, 2008 | 09:45 PM
HOODLOVER's Avatar
Default Re: Spiratic IDOLING???? (crxsirg)
are you leaking coolant OUT of your car??and how much coolant did you have to put back into the rad??
Old Sep 23, 2008 | 10:27 PM
b16-ef-si's Avatar
by "i put in water" u mean i put in coolant riiiiiight??????
cus if ur just adding water u are lowering ur boiling point big time...
and thats not good
Old Sep 24, 2008 | 05:56 AM
cor4ey's Avatar
ok so maybe I spelt it wrong sorry sporadic idoling yes but I filled it up with coolant the first time I filled it then just added some water to make it home.... its a jumpy idol not just a vacuum leak idol like up and down its all over now this morning when I started it up ran fine on a cold start till I drove to work but I will add more coolant to it but I don't think thatd be the problem.... as for how much water I added 3 lil arrowhead waters bottles 12 oz not sure headgaskets maybe 12000 miles on it...
Old Sep 24, 2008 | 09:37 AM
wasabivtec's Avatar
You said it runs hot going up a hill I would lean towards a headgasket. If your filling that much fluid into it and dont see a leak, it could only be burning up. I would assume you cleaned the IACV when you had it off already. As far as the "Idoling" issue do you mean to say that its not hunting but rather extremely rough and low and gives you a great lag in throttle response. If thats the case...headgasket
Old Sep 24, 2008 | 10:52 AM
HOODLOVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wasabivtec &raquo;</TD></TR><TR><TD CLASS="quote">You said it runs hot going up a hill I would lean towards a headgasket. If your filling that much fluid into it and dont see a leak, it could only be burning up. I would assume you cleaned the IACV when you had it off already. As far as the "Idoling" issue do you mean to say that its not hunting but rather extremely rough and low and gives you a great lag in throttle response. If thats the case...headgasket</TD></TR></TABLE>
Old Sep 27, 2008 | 07:51 AM
cor4ey's Avatar
so now heres the issue soon as i turn on the car wait for the check engine light to go off it never does and i cant take it past 3500rpm i did reset the ecu and i have a "custom" setup so to speak was a dual point 1.5l motor swapped to obd1 multi point 1.6 vtec.... running a po6 does anyone know the color of the two wires to bridge that will tell me the code the ecus throwing?
Old Sep 27, 2008 | 09:27 AM
wasabivtec's Avatar
Im not positive I believe brown and green its a little connector on the passenger side thats by the a pillar and blower motor under the dash. Its the only one hanging there
Old Sep 27, 2008 | 03:38 PM
cor4ey's Avatar
k new info im throwing code 7 on the ecu.... and is there anything i need to do after checking the code (twisting the two wires together) do i need to reset the ecu? etc?
Old Sep 27, 2008 | 05:48 PM
91civiccross's Avatar
First thing I'd do is replace the thermostat. They get stuck open or closed some times.
That could be your entire over heating problem.
Old Sep 27, 2008 | 06:01 PM
beana's Avatar
are you using a p28 or at least an obd1 ecu
first thing i'd do is check the wires going to you coolant temp sensor
i know it sounds fishy but just go with it
Old Sep 28, 2008 | 12:48 PM
b16-ef-si's Avatar
do u have a thermostat at all?
like i took mine out and have my fans runnin all the time
if u dont have one it could be causing u to over heat...sound dumb i know u would think that since water ehh coolant is always circulating it be cooler but since the coolant isnt staying as long in the radiator to cool down ur getting hot cooolant back into ur engine making it over heat...i had some problems with a buddys eg it over heated like crazy cus the cap couldnt hold any pressure and he didnt have a thermostat...
Old Oct 4, 2008 | 11:48 AM
cor4ey's Avatar
ok so im not entirely worried bout the overheating anymore I fixed that what im trying to figure out is the sporadic idoling and the 3500rpm cutoff im getting all with code 7.... but the crazy **** is if I reset the ecu "unplug and wait then plug back in" it goes away untill I really rap out the motor...... doesn anyone have advice for this issue? not overheating....
lancethomas
15
Sep 18, 2010 06:20 AM
PinoyDelS0l
Jun 5, 2009 01:03 PM
iwanttogofast
Apr 2, 2008 04:53 PM
Shaminda
15
Jun 9, 2006 10:18 AM
simike
Aug 2, 2002 01:29 PM
