idle problems, GSR swaped EK
Old Sep 23, 2008 | 12:25 PM
quicksilver1689's Avatar
i ♥ snails
Modified by quicksilver1689 at 9:12 PM 9/28/2008
Old Sep 23, 2008 | 01:21 PM
hondapwr's Avatar
Default Re: idle problems, GSR swaped EK (quicksilver1689)
It seems odd that you have no change when you pull the vacuum line off the FPR. Both my D16Z6 and B16A rev up a bit when I pull off the FPR vacuum line (FP increases too).
I would get a fuel pressure gauge and a vacuum gauge and do some tests!
Old Sep 23, 2008 | 01:35 PM
JdelMsolG's Avatar
Default Re: idle problems, GSR swaped EK (hondapwr)
i had almost the same exact problem you are describing on a b16.
i couldnt figure it out but its in the shop now, and i should hear what it was either tomorrow or thursday.
Old Sep 24, 2008 | 08:40 AM
i ♥ snails
anybody else have any insight? when we connected the iACV it idles really high at like 3.5k. The conversion from the 3 wire IACV to the 2 wire was done. what do you guys think about the fuel pressure regulator being faulty? cuz these problems just started happening, and also the IACV could be disabled in the hondata program right?
Old Sep 24, 2008 | 08:44 AM
egasleep's Avatar
I had the same prob on my gsr swapped eg , the fuel pressure regulator was shot . It was dumping way to much fuel and running pig rich which caused the car to have a choppy idle and dump fuel out the pipe . I would definantly look into the fuel system .
Old Sep 28, 2008 | 12:40 PM
i ♥ snails
what else do you think could be wrong, we replaced the FPR the other night, little to no change.
Old Sep 28, 2008 | 04:55 PM
i ♥ snails
any ideas guys?
Old Sep 28, 2008 | 05:05 PM
gsr96cx's Avatar
is it throwing any CEL? if not check your timing/ and ignition timing.
Old Sep 28, 2008 | 08:11 PM
i ♥ snails
valve and ignition timing are perfect, im a idiot, i should have hooked up the vaccum guage right off the bat, it was a defective IM gasket. case closed. thanks!
B_Swapped93
Mar 25, 2013 10:35 AM
smoovy
Aug 12, 2009 02:28 AM
integrals1289ss
Oct 7, 2007 10:20 AM
DropSquadCivic
Oct 19, 2003 03:21 PM
BeeT
Jun 18, 2001 10:00 AM
