Ok simple one for all u tech-heads
Old Jul 26, 2002 | 10:45 AM
HatchBox's Avatar
Skoobie no more...
Default Ok simple one for all u tech-heads
Has anyone ever installed a cig lighter in a 90 honda civic dx...there was no cig ligher so i bought a universal..and it says all wiring is in the car...but i have no idea wich wire goes to the cig lighter...any ideas...
Old Jul 26, 2002 | 11:07 AM
BROOD's Avatar
Default Re: Ok simple one for all u tech-heads (xxkenyon419xx)
I imagine chassis ground and 12volt switch power are all that is needed.
12volts switch so the lighter is not on while the car is off.
And possibly a 12volt illumination wire if it is a lighted cig. lighter.
Finding the correct power sources is easy with a multi-meter. Good luck
[Modified by SLPR, 12:07 PM 7/26/2002]
Old Jul 26, 2002 | 11:10 AM
HatchBox's Avatar
Skoobie no more...
Default Re: Ok simple one for all u tech-heads (SLPR)
i dont think i got a 12 volt power switch
unless its with the plug
there is a little clip tho behind the dash...its not pluged into anyth it has 1 red, 1 red with black stripe, 1 black wire, and a white wire with green stripe...it wont plug into the cig lighter..but should i use one of those wires ??
[Modified by xxkenyon419xx, 12:29 PM 7/26/2002]
[Modified by xxkenyon419xx, 12:50 PM 7/26/2002]
Old Jul 26, 2002 | 12:05 PM
HatchBox's Avatar
Skoobie no more...
anyone...
Old Jul 26, 2002 | 12:42 PM
salbaje's Avatar
the plug for cig lighter is the L shaped one
Old Jul 26, 2002 | 02:15 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Ok simple one for all u tech-heads (salbaje)
nope dont have one of those...
Old Jul 26, 2002 | 02:48 PM
Mista Bone's Avatar
D Tranny Guru
well, civic DX's came with a lighter, STD's did not.
Old Jul 26, 2002 | 07:44 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Ok simple one for all u tech-heads (Mista Bone)
r u sure 90 dx didnt have one ..cuz it has a peferated cut out for one...and the reason i ask is because on the original recept of sale from honda its listed as dx
Old Jul 26, 2002 | 08:05 PM
BreakStuff's Avatar
New User
it could have been an "option" if the cut-out is there.. and if thats the case then the factory wiring would be located somewhere near that cut-out and you could always "steal" power from that un-used connector.. just remember that this is a lighter and will draw high amperage so the original wire will be thicker in diameter than the other wires.. if you are not sure than you could always run a single fused wire straight from the battery for power, and connect the ground wire to the chassis behind the center console..
Old Jul 26, 2002 | 08:19 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Ok simple one for all u tech-heads (BreakStuff)
but if i ran a wired directly from the battery wouldnt it be on all the time..even whe the car is off??
Old Jul 26, 2002 | 08:23 PM
BreakStuff's Avatar
New User
yes, it would.. but anyhoo.. if you visually look at the fuse block you should see a few empty 1 pin terminals that were placed there for factory options...some of these terminals will be switched power, some constant power.. you could always steal power here as well, just make sure to install an inline fuse for added protection..
Old Jul 26, 2002 | 08:34 PM
HatchBox's Avatar
Skoobie no more...
could u perhaps tell me where the cigerette litghter fuse would go in the fuse block... and if not should i just go trial and error then...
Old Jul 27, 2002 | 03:09 AM
EG6-SiR's Avatar
New User
Dang you must really like smoking...
Get a zippo...
Old Jul 27, 2002 | 12:33 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Ok simple one for all u tech-heads (EG6-SiR)
No i just wanna have a cig lighter so i can use my new radar detecter
Old Jul 27, 2002 | 03:22 PM
HatchBox's Avatar
Skoobie no more...
ok i found that there is a fuse for a cigerette lighter...so i put a wire from the fuse to the cig lighter...i even put a inline fuse...it lights up...but wont put any heat out...?? what to do now
Old Jul 28, 2002 | 12:12 PM
HatchBox's Avatar
Skoobie no more...
nobody....common this is simple for u
Old Jul 28, 2002 | 03:33 PM
earl's Avatar
Does it have a good ground also?
Old Jul 28, 2002 | 05:15 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Ok simple one for all u tech-heads (earl)
yeah has a really good ground.. idk if i hooked the wire up to it right tho...i put the wire on the 1 tong of the fuse that goes into the fuse box so that the wire is connected...should i have power?
jnemci
Jan 11, 2010 06:16 PM
rugimpy
Audio / Security / Video
40
Dec 2, 2009 06:51 AM
sloem2
Honda Civic (2001 - 2005)
May 14, 2007 08:25 PM
tyrone2982
Jan 6, 2006 08:07 PM
jdl3000
Jul 31, 2004 03:50 PM
