d17a2 blocc
Old Sep 22, 2008 | 10:38 PM
nitewolf's Avatar
Default d17a2 blocc
is it any good? and can i use it? found one for cheap
Old Sep 22, 2008 | 10:49 PM
D16SiHatch's Avatar
Default Re: d17a2 blocc (nitewolf)
im not aware of any mount kits that will allow you to use it, and i've never heard of anyone using it. so i'm gonna go out on a limb and say no. not without some major fab
Old Sep 23, 2008 | 03:55 AM
daddy's Avatar
Default Re: d17a2 blocc (D16SiHatch)
the D17 is not very compatable with the other D series parts. if your asking can you use a D17 block and a D16 head the answer is no.
Old Sep 23, 2008 | 06:44 AM
overrev_it's Avatar
Default Re: d17a2 blocc (daddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy &raquo;</TD></TR><TR><TD CLASS="quote">the D17 is not very compatable with the other D series parts. if your asking can you use a D17 block and a D16 head the answer is no.</TD></TR></TABLE>
there is some modification requird to make it fit...
to the op, i don't how much fab work you would run to install it on your chassis but for the same amount of fab and some extra cash you could get you a nice k swap for sure..
otherwise just stick with a b/f/h swap and that's just my opinion
Old Sep 23, 2008 | 10:00 AM
0_civic_4's Avatar
ive seen the swap and it put out really good numbers but there is a **** load of work you have to do. the block needs to be machined to fit. the pistons need to be machined for valve clearance. all the pulleys and gears on the side need to be changed alot of work.....
Old Sep 23, 2008 | 12:24 PM
nitewolf's Avatar
Default Re: d17a2 blocc (0_civic_4)
thanks for the replys....
how about the head?
Old Sep 23, 2008 | 05:35 PM
n3h3bkau's Avatar
Head swap... nah.
If you were going to do anything you could steal the block internals from the d17 but than you'd have to tune the thing.
Old Sep 25, 2008 | 02:12 AM
daddy's Avatar
Default Re: d17a2 blocc (n3h3bkau)
the bolt pattern of hte head is different
Old Mar 14, 2010 | 06:48 PM
jdmshocker88's Avatar
TRIAL USER
Sell the d17a2 to me....
skateboard c
Oct 13, 2008 07:26 AM
95civiccpdx
Aug 21, 2007 10:54 AM
whiteb16crx
Apr 16, 2007 12:03 PM
93formula
Jan 13, 2005 06:50 PM
PatiKTP
Dec 16, 2002 01:04 PM
