Some clutch issues
Old Sep 22, 2008 | 07:38 PM
Deano_D aka
Default Some clutch issues
I got my beater running and driving yesterday (89 4 door, d16z6, si trans) here is the only issue left. When I am in low rpms it shifts like butter, but if I shift at redline it will not go into gear unless you force it (grinds of you force) or double clutch (will not grind).
Old Sep 22, 2008 | 07:41 PM
sleepingciv's Avatar
Default Re: Some clutch issues (Deano_D aka "Brick Top")
syncros
Old Sep 22, 2008 | 07:46 PM
Deano_D aka
Default Re: Some clutch issues (sleepingciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">syncros</TD></TR></TABLE>
It seems odd that the trans will not go into any gear (1st to 2nd to 3rd to 4th to 5th) but is butter buttter smooth if you force the grind is not bad the real problem is it just does not want to go into gear in the high rpms. Maybe the clutch cable is not adjusted right?
Old Sep 22, 2008 | 07:50 PM
you can try to adjust it maybe the clutch is getting down there and needs replaced.
Old Sep 22, 2008 | 07:51 PM
Deano_D aka
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">you can try to adjust it maybe the clutch is getting down there and needs replaced.</TD></TR></TABLE>
The clutch seems good also no slips at all, the clutch grabs realllly high..
Old Sep 22, 2008 | 07:54 PM
ok then if it dont slip the cable needs no adjustment that leaves the throw out bearing, pressure plate and syncros. When was the last time the trans fluid was changed?or level checked
Old Sep 22, 2008 | 07:58 PM
Deano_D aka
I put synchromesh in yesterday when I finished the swap, how many quarts is it I used a tad over 2, the trans does not make a single whirring or whining sound super quiet. I have never had a cable trans so I thought the damn cable is giving me issues ALSO I did loose the cable stay that bolts on the valve cover could that cause this (extra flex).
Old Sep 22, 2008 | 08:24 PM
the cable stay not a big deal i dont have one either
you might nor be use to the cable trans yet, if ya never had one
fluid is suppose to b 1.7 one a fliud change and 1.9 on a rebuild so you should be good
Old Sep 22, 2008 | 08:37 PM
Deano_D aka
Hmmm I will re-adjust the cable and update you tommorow. I am pretty sure it is to tight my buddy was fiddiling with it yesterday and he probably just cranked it all the way down...
philkehn
Oct 27, 2006 06:58 AM
z51LS2
Apr 16, 2006 05:17 PM
verycleanhatch
Oct 6, 2005 03:43 PM
preluda
Aug 22, 2005 09:50 PM
Steve90HB
Sep 18, 2003 01:09 PM
