Bore on An ls
Old Sep 22, 2008 | 02:51 PM
allmotorlscrx's Avatar
Default Bore on a ls
What would be a safe Bore to go to on an Ls block being built for an all motor setup. I want to go as big as i can.
Old Sep 22, 2008 | 02:56 PM
CerealKiller's Avatar
Default Re: Bore on a ls (allmotorlscrx)
are you stock or sleeved?
Old Sep 22, 2008 | 03:03 PM
Default Re: Bore on a ls (CerealKiller)
as of right now it is stock but i will sleeve it if i have too
Old Sep 22, 2008 | 03:07 PM
stock 81.50mm safely
sleeved 86mm
Old Sep 22, 2008 | 03:17 PM
ok thanls
Old Sep 22, 2008 | 03:20 PM
4g hatch's Avatar
82mm is the max
Old Sep 22, 2008 | 03:30 PM
RPRacing's Avatar
to clarify what both people above said is this
if you stay with stock sleeves, you can only go 82mm max. I've done it on a few motors. there is plenty of sleeve there.
if you plan on sleeving, the biggest I would run on the street is 85mm. Anything bigger and you risk the reliability factor (mainly due to cooling/head gasket issues).
If its just going to be driven at the track, or when racing (no cruising around/Daily), then you can go 86mm on most sleeves, some even 86.5mm. But be prepared for minor issues to hurt the motor easier.
Hell, on my race car, I only went with a 85x95 setup so I could go bigger later if something ever happened. Sometimes you need to sacrifice making some power to enjoy longevity/piece of mind.
hope this helps.
Old Sep 22, 2008 | 04:42 PM
Default Re: (RPRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">to clarify what both people above said is this
hope this helps. </TD></TR></TABLE>
x2
Old Sep 22, 2008 | 04:55 PM
Big Teggie's Avatar
I agree with Francisco.
82mm on stock sleeves
85mm on aftermarket sleeves
What are your power goals? You might be able to achieve you goal with stock sleeves.
Old Sep 22, 2008 | 06:11 PM
ok yea i was think about goin 84mm this is only going to be a track car. Also would an ls hold up to 13:1+ compression i am trying to get all the power i can get out of an ls
Old Sep 22, 2008 | 06:13 PM
RPRacing's Avatar
compression is all about the cams, gas and tune. put a good combination of 3 together and you're golden.
but to answer your question, yes.
Old Sep 22, 2008 | 06:22 PM
i am planning on running web cams with the hondata s300
Old Sep 22, 2008 | 06:26 PM
RPRacing's Avatar
if you're going to run their cams, I would talk to them (or Bisi) about what compression they would like to see. You cant just pick common numbers. There is some technical reasons why more or less compression is good/bad
Old Sep 22, 2008 | 06:37 PM
yea i was planning on get the motor built then talking to them once i have all the perts and know my exact setup before getting the cams
Old Sep 22, 2008 | 06:50 PM
RPRacing's Avatar
no no no. do the other way around. decide what cams make power where you want. (based on trans/tires, etc) then build around that.
Old Sep 23, 2008 | 12:41 AM
well the trans i have is an ls cable but i was planning on switching the gears out should i compensate for that
Old Sep 23, 2008 | 03:56 AM
RPRacing's Avatar
you need to do some more research if you're going NA.
thats a terrible transmission to use.
Old Sep 23, 2008 | 04:37 AM
yea i know it came with the swap wat trans would u recommend
Old Sep 23, 2008 | 04:53 AM
RPRacing's Avatar
depends on what tires/rims you use and how high you want to rev the car. you definately want some sort of short geared trans. usually, a 4.7 ITR trans is a standard all motor trans. get you right in the ballpark for most basic tire/motor setups.
Old Sep 23, 2008 | 05:11 AM
I run a 24.5/8.0-14 Mickey Thompson slick on 14 in eagle rims
hondacura22
May 21, 2008 05:44 PM
philliedawg
12
Oct 18, 2007 10:26 AM
efKART
Mar 3, 2007 01:41 AM
escape2me
10
Apr 25, 2004 08:20 PM
DLB1994
Jun 10, 2002 08:02 PM
