reusing used forged pistons. what should I pay close attention to?
Old Sep 22, 2008 | 05:47 AM
dpine's Avatar
Default reusing used forged pistons. what should I pay close attention to?
I have had thses pistons for years. My friend gave them to me from his old b20vtec engine.
The origional engine that they were in had a rod bearing failure and scarred the crank after a few hundred miles. So he sold the rods and gave me the pistons. Up until now I didn't have any ententions to use these pistons other than paper weights how ever I may be building a motor in the next few months (trying my first one). So if I am going to use the pistons what should I look for as for "weaknesses or imperfections" in them? Should I order new rings aswell?
Thanks
Old Sep 22, 2008 | 06:02 AM
Fkned's Avatar
Default Re: reusing used forged pistons. what should I pay close attention to? (dpine)
If you are worried about them being cracked there is a spray that we use to find cracks in alum.It's a 2 part spray most race shops will have it on hand or know what to order to check for you.
If your worried about them being out of spec take them to a shop and have them measured against the stock specs from the piston manufacturer.
Old Sep 22, 2008 | 07:33 AM
dpine's Avatar
Default Re: reusing used forged pistons. what should I pay close attention to? (Fkned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned &raquo;</TD></TR><TR><TD CLASS="quote">If you are worried about them being cracked there is a spray that we use to find cracks in alum.It's a 2 part spray most race shops will have it on hand or know what to order to check for you.
If your worried about them being out of spec take them to a shop and have them measured against the stock specs from the piston manufacturer.</TD></TR></TABLE>
I am more worried about the warping and if there are hot spots on the pistons and how to tell.
Old Sep 22, 2008 | 08:02 AM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote">I am more worried about the warping and if there are hot spots on the pistons and how to tell.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned &raquo;</TD></TR><TR><TD CLASS="quote">If your worried about them being out of spec take them to a shop and have them measured against the stock specs from the piston manufacturer.</TD></TR></TABLE>
Old Sep 22, 2008 | 10:02 AM
RPRacing's Avatar
1-take them to a machine shop to have them:
-cleaned
-inspected
-weighed
-measured
2-order new rings (this is mandatory, besides being a good suggestion)
3-order new wrist pin clips (I dont know what brand pistons you have or if they're sprial locks, or clips or what, but you need to order 4 sets of clips)
other than that, you should be good to go.
Old Sep 22, 2008 | 10:46 AM
DonF's Avatar
Default Re: reusing used forged pistons. what should I pay close attention to? (RPRacing)
The above, plus measure the ring to groove clearance. A feeler guage is all that is necessary.
Old Sep 22, 2008 | 03:08 PM
unusual71's Avatar
A shop will be able to tell you if they are warped pretty easy without needing to see any sort of manufactures specs. I say if they aren't cracked or warped they are as good as new.
Old Sep 22, 2008 | 03:42 PM
RPRacing's Avatar
Default Re: (unusual71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unusual71 &raquo;</TD></TR><TR><TD CLASS="quote">A shop will be able to tell you if they are warped pretty easy without needing to see any sort of manufactures specs. I say if they aren't cracked or warped they are as good as new.</TD></TR></TABLE>
I say I hope you dont build motors for customers. or hell, even yourself
B18 CYA
Apr 9, 2007 06:38 PM
efcivic757
Feb 8, 2007 04:07 AM
MessGSR
Jan 27, 2006 11:43 AM
NotPhilTran
Feb 7, 2005 05:55 AM
RACING INTEGRATION
Nov 19, 2004 04:41 PM
