Cannot reuse pistions?
Old Jan 25, 2006 | 07:51 PM
MessGSR's Avatar
Default Cannot reuse pistions?
i head a rumor that you cannot reuse pistions, because after piston and rings have been pressed once, if you try to reuse, pistons again, even with new rings, there can be play, and not be good for your motor. is there any truth to this rumor?
Old Jan 25, 2006 | 11:44 PM
EnzoSpeed's Avatar
Default Re: Cannot reuse pistions? (MessGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR &raquo;</TD></TR><TR><TD CLASS="quote"> is there any truth to this rumor?
No. You have to buy new rings though.
Old Jan 26, 2006 | 06:06 AM
Fkned's Avatar
Well there is some truth to that if you had the pistons on/off rods.I would never reuse a piston that had been pressed off a piston,if thats what you mean.
Old Jan 26, 2006 | 06:13 AM
Flashmn's Avatar
Default Re: Cannot reuse pistions? (Fkned)
Nope, you can reuse pistons just fine.
Pistons pressed off pistons, wtf?
Old Jan 26, 2006 | 10:10 AM
MessGSR's Avatar
Default Re: Cannot reuse pistions? (Flashmn)
i appoligize, i kinda of wrote it retarted, i meant can u reuse psitons after they have been pressed on to a rod, example, my buddy has a jdm b16, but i am builinding lsvtec, can i use his pistions on my ls rods? even if i used new everyting, i heard there could be a problem with the piston maybe having movment from alrdy being pressed?
Old Jan 26, 2006 | 04:57 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">Pistons pressed off pistons, wtf?</TD></TR></TABLE>Sorry ment off a pin
Old Jan 26, 2006 | 05:08 PM
ekek888's Avatar
thats rumor and as long as the piston was removed from rod w/care u can reuse it.
Modified by ekek888 at 2:21 AM 1/27/2006
Old Jan 27, 2006 | 11:43 AM
MessGSR's Avatar
Default Re: Cannot reuse pistions? (ekek888)
ok
oxSLEEPERxo
Jun 24, 2007 12:11 PM
all_motorsi
Apr 21, 2007 02:14 PM
WalkerGSR1
Sep 4, 2006 10:53 AM
b18ek670
May 2, 2006 04:54 PM
jfoster
Jan 6, 2005 05:53 PM
