help plzz
Old Sep 21, 2008 | 09:35 PM
88civii's Avatar
Default help plzz
First off, thank to any1 reading this, but anyway, im new to the forum, and semi- new to hondas, i've had my 88 civ [automatic] for almost a year but i've finally decided to make it a project, i wanna hook it up, but honestly i don't know where to start. well i kno 1st and foremost, under the hood work comes first, ive been hearing suggestions like getting a brand ne air intake & exhaust system, and a couple other things[ tune up, spark plugs/wires etc.] I want another engine, but their pricey and idk which 1 to even consider getting. . . . .
am i heading in the right direction?
plz help if u can.
Old Sep 21, 2008 | 11:59 PM
sleepingciv's Avatar
Default Re: help plzz (88civii)
Id first start off by doing a manual swap, then a dpfi tp mpfi swap do a mini me set up on the car, its cheap, then a supension set up like some coil overs
Old Sep 22, 2008 | 12:06 AM
88civii's Avatar
Default Re: help plzz (sleepingciv)
Thanx for the help, u kno how much manual swaps run? I've heard they kan get a little pricey bro
Old Sep 22, 2008 | 12:32 AM
D16SiHatch's Avatar
depending on how much you can get the transmission for it shouldnt be all that bad. I did a 5spd swap on my mustang but i'm not sure what all is involved for a honda. Obviously you'll need the 5spd trans itself. i imagine you'd need the manual passenger side tranny mount as well. you'll need stock linkages for a stick as well. and also a manual tranny ecu. most likely the center shift console from a manual as well, with the shiftboot and whatnot.
Old Sep 22, 2008 | 12:33 AM
na there not that bad and easy to do
manual peddals any where from 10 to 30 bucks
a used dx or si trans 50-150
clutch cable 15 or so used
a used manual dx computer 10-30
some other stuff also
you can get all your swap stuff here on honda tech lol
its not that bad at all
heres a link
http://rywire.com/store/auto2man.php
Old Sep 22, 2008 | 08:37 PM
88civii's Avatar
thanx to both dudes for the input, but yo sleeping civ, i saw the myspace, nice hatch, and nice paint on th engine, that ***** sweet
Old Sep 22, 2008 | 08:51 PM
xileap2's Avatar
Start with your suspension. 90-93 rear disc, mc/booster and 40/40 prop valve.. Then you can go with the mini me swap; zc vtec or d16 and turbo that puppy.
Brett1414
Dec 5, 2014 03:57 PM
da1992integra
Transmission & Drivetrain
May 18, 2010 01:45 PM
DOHCED8
11
Jan 15, 2009 06:56 PM
EpicKills
Southern California
Jun 14, 2008 11:59 AM
5Gs3PR
May 12, 2004 02:49 PM
