painting my entire floor panel need advice
Old Sep 21, 2008 | 06:21 PM
danthemang3's Avatar
Default painting my entire floor panel need advice
well i'm doing a ground up project on a $200 shell i found. topic will be posted soon in the integra forum with pics of progress. but i have the entire floor panel stripped and sanded. i beleive i need to go with a epoxy primer because i do have some bare metal? do i need to use a sealer? then i want to paint it the color i want to paint the car. i'm not going to clear it because most of it will be covered. i'm not worried about it being perfect just decent. i'm leaving the outside to the pro's but want to take care of this myself. so any advice would be much appreciated. thanks.
Old Sep 23, 2008 | 06:33 PM
singlecamslam98's Avatar
Default Re: painting my entire floor panel need advice (danthemang3)
i had a water leak and was worried about my floor board rusting, painted it with rust bullet with a brush and it was easy and looks good, and now i dont have to worry about it ever rusting, hope this helps
Old Sep 25, 2008 | 04:10 AM
powerflow's Avatar
Default Re: painting my entire floor panel need advice (singlecamslam98)
I would prep it really good, epoxy sealer (wet on wet method), flash, then single stage.
Using single stage will be more durable since it has clear and hardener.
Old Sep 26, 2008 | 04:42 PM
syzurs's Avatar
make sure you prep the bare metal correctly and then use etch primer
TB123
Paint and Body
Aug 2, 2013 09:14 AM
01-0720
Paint and Body
Mar 9, 2012 04:20 PM
11secEk
Paint and Body
Dec 28, 2007 08:08 PM
racebucket_eg
Paint and Body
45
Nov 9, 2007 04:14 PM
Buktheng
Mar 6, 2005 11:17 PM
