Trying to reduce height on shifter
Old Sep 21, 2008 | 05:56 PM
GSE980's Avatar
Default Trying to reduce height on shifter
My del sol is about done B swap with a home made turbo kit all the work did in driveway at my apartment... NE wayz my stock gsr shifter is high as hell and I need something shorter that I can actually put a boot on and hide the ground below..I am looking a fidanza but I read up on a thread that they are the same hieght as stock
someone please help
Old Sep 21, 2008 | 06:19 PM
Decaf's Avatar
get a skunk2 short shifter
Old Sep 21, 2008 | 06:22 PM
hj2's Avatar
hj2
i gots the skunk2 short shifter, is nice but im not used to it yet
Old Sep 21, 2008 | 06:39 PM
GSE980's Avatar
whats the difference in height
Old Sep 21, 2008 | 06:43 PM
cehcivic15's Avatar
Default Re: Trying to reduce height on shifter (GSE980)
cut your shifter where you want it and epoxy the **** onto it..done!
Old Sep 21, 2008 | 06:48 PM
GSE980's Avatar
is that what you did??
Old Sep 21, 2008 | 11:26 PM
Kupo's Avatar
Default Re: (GSE980)
cut it down and re thread it
Old Sep 21, 2008 | 11:32 PM
Aushonda's Avatar
Default Re: (Kupo)
Skunk 2 short shifters sit pretty high on del sols so I've heard. I've got one myself but it's not installed.
Old Sep 22, 2008 | 04:05 AM
madracer's Avatar
Default Re: (Decaf)
If you want to do it right, Then figure out the height you want, then take the shifter and **** to a machine shop and have them cut it to the height, some machining maybe needed on the outer surface then retread it for the ****.
Note: Depends on the hieght you want the shifter starts thin on the top and get's a little bigger as you go down and that is why the shifter may need some maching on the outer surface before retread.....
That"s how i would do it, no epoxy and it won't break in the future and still look like factory.
Good luck..
Old Sep 24, 2008 | 07:41 PM
GSE980's Avatar
why a machine shop??? Couldn't I just use a tap and die kit and if its to thick just grind down the sides to size then sand to a circular shape.. Just stating an alternative so peeps dont have to spend money at a machine shop they can make some money themselves rather then spend it... ANybody have a dEL SOL WITH THE SKUNK 2...??? How does it sit??compared to a stock bseries shift linkage
Old Sep 24, 2008 | 07:56 PM
cheesecheda's Avatar
my del sol had a ebay short shifter on it and it did sit pretty high, when it broke i replaced it with a stock b-series shifter which sat about the same so I grabbed a jigsaw cut it to height i liked rethreaded the shifter and i was good to go.
Old Sep 24, 2008 | 08:02 PM
sorrule's Avatar
they all sit high, B&m shifters are probably among the shorter ones
Old Sep 26, 2008 | 06:35 PM
GSE980's Avatar
i think Im going to try B&M
Old Sep 26, 2008 | 07:50 PM
john666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kupo &raquo;</TD></TR><TR><TD CLASS="quote">cut it down and re thread it</TD></TR></TABLE>
done and done
Old Sep 26, 2008 | 09:01 PM
Since 1983's Avatar
my friend has an MR2 and he actually wnt out and bought a lowering plate for it, im not sure exactly the specifications or anything but we just ahd this conversation because I want to lower my shifter on my del sol as well, I will ask him where he got it from and see if he remembers
Old Sep 27, 2008 | 12:56 AM
boostedhks's Avatar
Default Re: (Since 1983)
**** looks hot, just like the supras
SoyMilk
55
Mar 27, 2010 10:11 AM
PhrequenC
53
Jun 28, 2007 09:57 PM
EJ8 GSR-T
Dec 13, 2006 10:20 AM
VINtegra90
Sep 19, 2005 11:28 AM
ITR571
Jul 21, 2001 04:00 PM
