Valves not seating??? HELP
Old Sep 20, 2008 | 11:57 AM
SPOONfed-Rex's Avatar
Default Valves not seating??? HELP
So I have a 99 b16 head . It's going on a 99 gsr block. I did my springs, retainers and valve seals (I used all Supertech) and I'm pretty sure I did a good job on the head. I used the tool from Ebay that everyone on here recomends. So I took it to a machine shop to get it milled and the guy at the shop told me the valves are not seating right on ALL cylinders. Do the valve seals need any special way to be changed.. I used a socket and a soft hammer to seat the valve seals all the way down.. Was it my fault or is this guy trying to herb me for some more money??
Old Sep 20, 2008 | 12:23 PM
Combustion Contraption's Avatar
Default FV-QR
He's telling you the valves are not sealing against their seats. That has nothing to do with the valve seals you installed. He probably wants to do a valve job for you. If you trust him, do it. If not, take your business elsewhere.
Old Sep 20, 2008 | 12:54 PM
DonF's Avatar
Default Re: FV-QR (Combustion Contraption)
Its only NINE years old. I know Honda valve jobs are good for 10.
Old Sep 20, 2008 | 01:07 PM
Fkned's Avatar
Default Re: FV-QR (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Its only NINE years old. I know Honda valve jobs are good for 10.</TD></TR></TABLE>
Old Sep 20, 2008 | 01:13 PM
Default FV-QR
Yup. Big 45 lasts a long time.
Old Sep 20, 2008 | 01:20 PM
Fkned's Avatar
I don't quite know if the sarcassim has made it through the posts,lol.
Have him show you it leaking either thru a vaccum test or if they are really bad putting solvent or some other thin fluid other then water in the ports and see if they leak from the valves.
Old Sep 20, 2008 | 02:18 PM
DonF's Avatar
Default Re: FV-QR (Fkned)
Why bother, just put the head on with the new springs and cams and bitch about the tuner only getting 187 WHP when everyone else in the US is getting 200. I am sure a nine year old valve job and carbon build-up will support 200 wheel. Why even surface the head, Honda work not good enough?
Old Sep 20, 2008 | 02:22 PM
d15Beta's Avatar
new valves + old beat up valveseat (no new vj) = extra cfm seeping thru when valves are shut
= fantabolous WHP result
Old Sep 20, 2008 | 08:18 PM
Default Re: (d15Beta)
No not aftermarket vavles...I used the stock valves and never moved them from their original place..
Old Sep 20, 2008 | 08:30 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Valves not seating??? HELP (SPOONfed-Rex)
You might want to get a valve job.
Old Sep 20, 2008 | 08:50 PM
ruffrhyder's Avatar
Should defintately get a performance valve job. At the very least, regring the seats to ensure proper seal. Listen to guys who have replied to your post, they are the best of the best at what they do
kornerk12
11
Jul 3, 2009 03:55 AM
SPOONfed-Rex
Sep 25, 2008 09:01 PM
djnikko
Nov 17, 2006 06:05 AM
7rrivera7
Nov 7, 2005 03:11 PM
JeffNA
May 20, 2002 06:59 AM
