How to clean valves? I have the valves out already.
Old Sep 19, 2008 | 11:42 AM
vtecn8ive's Avatar
Default How to clean valves? I have the valves out already.
I'm in the middle of changing my valve seats and wanted to know a good way for removing the carbon build up.
I had the head degreased when they resurfaced it, but i had the valves in. Just saying .
I already have the valves out and am wondering what the best method for removing the carbon build up?
I'm debating break cleaner, oven degreaser?
-Shane
Old Sep 19, 2008 | 12:10 PM
obuhmyuh's Avatar
Default Re: How to clean valves? I have the valves out already. (vtecn8ive)
you could always just buy new ones, they're relatively cheap.
but carb cleaner would probably do that trick.
Old Sep 19, 2008 | 12:15 PM
slvrcvc93's Avatar
Default Re: How to clean valves? I have the valves out already. (obuhmyuh)
i use a brass wire wheel very light will not scratch and does the job carb cleaner will work if there not that dirty
Old Sep 19, 2008 | 12:39 PM
Dkober101's Avatar
carb cleaner and drimmle tool with soft plastic polishing wheel
Old Sep 19, 2008 | 01:16 PM
vtecn8ive's Avatar
Default Re: How to clean valves? I have the valves out already. (Dkober101)
i sprayed brake cleaner in a shot glass, put a valve inside it and then sealed it up in a zip-loc bag. I'm going for a run so i'll check back on it later to see if it comes off easier.
maybe brake cleaner was not the right stuff to get?
Old Sep 19, 2008 | 01:23 PM
JohnnyWash1's Avatar
I would assume easy off oven cleaner would do the trick.
greenteadude
Sep 4, 2012 09:40 PM
NocTurNalFX
Mar 27, 2011 12:09 PM
vtecn8ive
Sep 24, 2008 05:41 AM
Boostn B20
Aug 21, 2008 08:02 PM
jdub db8
May 4, 2004 08:32 PM
