poorman's type r
Old Sep 19, 2008 | 10:47 AM
fatboys_ef9's Avatar
Default poorman's type r
i was wondering if i can just buy a gsr bottom block and use a b16 head and a b16 ecu to run the motor, what do you guys think? i need help im working on something nice
Old Sep 19, 2008 | 10:56 AM
98vtec's Avatar
moderator emeritus
Default Re: poorman's type r (fatboys_ef9)
why?
Old Sep 19, 2008 | 10:57 AM
Default Re: poorman's type r (98vtec)
why? i wanna know if that'll work....any ideas?
Old Sep 19, 2008 | 11:02 AM
knightsef-eg's Avatar
easily done... i cant exactially remember what it is..but the ports on the b16 head are better then the ones on the b18 .. and will actually make ur compression go up.... a pormans type-r is a decent way to make power ... if your on a budget...
good thing is that the gsr block has the oil ports and same with the head.. so you dont need to tap and run a ls-vtec oil line supply to the head...
id recommend it aswell.... but i can guarentee that people wont
98vtec's Avatar
moderator emeritus
will it work?
sure.
work correctly? probably not
if you are doing something nice, treat the engine right and get an engine management + tuning.
Old Sep 19, 2008 | 11:07 AM
cool, cause i just bought a gsr bottom last week and im tryna find a b16 head right now...i can use the b16 ecu right? thanks
Old Sep 19, 2008 | 11:08 AM
Default Re: poorman's type r (knightsef-eg)
thanks
Old Sep 19, 2008 | 11:17 AM
i have a virgin pr3 b16 head ... and a b16 ecu... im swaping over to a H2D
so .. did you get a good deal on the gsr block...let me know on how much you wanna spend on a head and ecu....
the head is in mint shape... 89xxx kms
Old Sep 19, 2008 | 12:24 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Putting a stock b16 head on a stock gsr block will NOT be a poor man's type r. It will make less power than a stock gsr due to the lowered compression and less agressive cams. Despite popular belief the pr3 head is NOT vastly superior to the p72 head from the factory. In fact 8 out of 10 times a GSR head will make more power on the same setup. The main advantage of pr3 heads is the choice of intake manifolds.
Old Sep 19, 2008 | 12:27 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: poorman's type r (2LEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Putting a stock b16 head on a stock gsr block will NOT be a poor man's type r. It will make less power than a stock gsr due to the lowered compression and less agressive cams. Despite popular belief the pr3 head is NOT vastly superior to the p72 head from the factory. In fact 8 out of 10 times a GSR head will make more power on the same setup. The main advantage of pr3 heads is the choice of intake manifolds.</TD></TR></TABLE> Well said.
I'm not sure why people don't like hearing this flat truth.
Old Sep 19, 2008 | 02:47 PM
ku's Avatar
ku
how much power will you gain from blox im on gsr head
Old Sep 19, 2008 | 03:57 PM
Deetz's Avatar
Crazy Honda Guy
Its should be noted that using a P72 head gives .1 higher compression over a pr3 due to the smaller square quench area.
The P72 head also has a slightly more direct airpath from the intake manifold to the valve which is provided good flow even at lower rpm which often makes 2-4hp to the wheels up to about 5500rpm over the pr3. That being said, the pr3 makes the same 2-4 hp more at the wheels over 5500rpm.
ol'skool ferio
18
Apr 16, 2008 08:56 AM
stock ek
Nov 9, 2006 06:22 PM
b20_driven
Oct 14, 2006 04:38 AM
FROSTDC2
Oct 27, 2005 09:40 PM
Jmorin
Sep 29, 2005 12:16 PM
