will skunk2 pro 2's do me much good?
Old Sep 19, 2008 | 07:05 AM
popwars123's Avatar
Default will skunk2 pro 2's do me much good?
whats up you guys i've searched but havnt found much on skunk2 pro2's
but I have a very good deal on a set and I am wondering if it will be overkill for my setup or not.
I have a first gen integra with an ls-vtec
it has jdm itr pistons, stock b16 head, arp rod bolts, shot peened ls rods itr oil pump/water pump etc.
it put down 174whp 136wtq with just a basemap
if i got these i would be getting the matching pro series retainers and valvepsrings and some adjustable cam gears...
so will these be optimal for me..or will it be too much cam for it
thanks
Old Sep 19, 2008 | 07:08 AM
IntegraType-R's Avatar
Default Re: will skunk2 pro 2's do me much good? (popwars123)
You can stick any cam in a motor and make power.. Where and when is a different question..
I personally want to upgrade from my s2s2's to the pro2's but i haven't had the money to find a good priced set on the cams..
I personally think it will be too much of a cam for that setup.. You can run it.. But you'll have to rev it alittle higher then what you would with pro1's I'd look more along the lines of the Pro1's, s2s2's , BloxC, rocket m22x. These cams you can rev to a good range but still keep the mid range and idle and low end... I'd say try the pro1's, if that works maybe you could get away with the pro2's
Keep in mind the pro2's are not your regular cam..
Contact Donf, b19, cleanrice, rocket and the other cam gurus around for information
Old Sep 19, 2008 | 07:31 AM
popwars123's Avatar
the blox cams look good but, they don't have much info on them and also i'm skeptical of them, I've always thought of them as an ebay company, so can anyone back up their products?
Old Sep 19, 2008 | 07:50 AM
Default Re: (popwars123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popwars123 &raquo;</TD></TR><TR><TD CLASS="quote">the blox cams look good but, they don't have much info on them and also i'm skeptical of them, I've always thought of them as an ebay company, so can anyone back up their products?</TD></TR></TABLE>
search
Old Sep 19, 2008 | 08:57 AM
Lubo_25's Avatar
the pro 2's generally prefer larger displacing set ups(2.0L+)...you will make more power but you wont be getting the full potential out of these cams....
Old Sep 19, 2008 | 12:14 PM
mx621's Avatar
Default Re: will skunk2 pro 2's do me much good? (Lubo_25)
i believe that pro2's only will work well in a very aggressive 1.8L . they worked good for me, but i would like to try some pro1's if the oportunity ever presented its self. as for you pro2's may not be ur best choice unless u wanted to upgrade other parts as well.
Old Sep 19, 2008 | 02:23 PM
dx_blk_hatch's Avatar
if any one needs pro 2 i have some for sale for a b motor only have 500 iles on them i wanted 450 obo
Old Sep 19, 2008 | 04:29 PM
Default Re: (dx_blk_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx_blk_hatch &raquo;</TD></TR><TR><TD CLASS="quote">if any one needs pro 2 i have some for sale for a b motor only have 500 iles on them i wanted 450 obo</TD></TR></TABLE>
Not to thread jack but i will trade you my s2s2's for the pro2's.. i have no money at this time, hurricane did me in pretty well.
Old Sep 19, 2008 | 05:53 PM
builtITRm22x's Avatar
Your motor doesn't seem to have enough compression to make power off the pro 2's. skunk2 stage 2's might be a better choice..
Old Sep 19, 2008 | 06:14 PM
Mhollaek9's Avatar
got stage 2 for sale 270 shipped
coupatroopa
May 23, 2011 08:37 PM
sloturbohatch
Sep 28, 2010 07:04 AM
usdm_dc2
Oct 3, 2007 09:46 AM
tbud454
Jul 28, 2004 11:13 AM
B00ST2nR
Apr 12, 2002 12:50 PM
