how much can a stock map sensor for a z6 hold up to.
Old Sep 19, 2008 | 05:25 AM
chinoslines's Avatar
Default how much can a stock map sensor for a z6 hold up to.
im boosting my del sol and just wanted to know how much could my stock map sensor hold up to without my engine being retarted.
Old Sep 19, 2008 | 06:06 AM
THC07's Avatar
Default Re: how much can a stock map sensor for a z6 hold up to. (chinoslines)
the firewall mounted Maps stop voltage at 10 the TB mounted stop at 11.
although you could hit 20psi, your voltage is not changing
Old Sep 19, 2008 | 06:08 AM
THC07's Avatar
Default Re: how much can a stock map sensor for a z6 hold up to. (THC07)
most know of what Crome says. 1.782 mbar and 11.2 psi
Old Sep 19, 2008 | 10:02 AM
gsrhatch2356's Avatar
The throttle body map is 11 psi, but if you are refering to the gm 3bar map then it can read alot more than 10psi obiviously "3 Bars" but if you dont have the motor built a little bit then you shouldnt go over 11psi anyway.
rnbguy
Jan 20, 2008 03:46 PM
daflagger
Nov 4, 2007 08:31 PM
MugenFlaredCRX
Jan 11, 2005 08:54 PM
CimorelliCRX
May 14, 2003 09:38 AM
DIRep972
Mar 11, 2002 07:01 PM
