civic with h22a1 swap
Old Sep 18, 2008 | 10:15 PM
eddy_dee's Avatar
Default civic with h22a1 swap
i would like to know if i can boost it with stock internals and how much boost can i run?
Old Sep 18, 2008 | 10:20 PM
civicjoe's Avatar
Default Re: civic with h22a1 swap (eddy_dee)
Can you boost it with stock internals? Yes
How much boost can you run? Depends on a lot of stuff.
Is it gonna go BANG! ? Depends if it's tuned.....properly.
Old Sep 18, 2008 | 10:29 PM
eddy_dee's Avatar
ok. thanks yea i plan on tuning with a p28 and crome.
Old Sep 18, 2008 | 10:41 PM
civicjoe's Avatar
Default Re: (eddy_dee)
check this out
https://honda-tech.com/zerothread?id=749784
of course that would never last as a dd
https://honda-tech.com/zerothread?id=316373
check out this thread and this one https://honda-tech.com/zerothread?id=691830
careful though a lot of people will tell you to be prepared when it blows, from the limited H series knowledge I have I wouldn't push more than 6 or 7 psi, depending on the turbo.
Old Sep 18, 2008 | 11:10 PM
eddy_dee's Avatar
Default Re: (civicjoe)
thanks for the info
Old Sep 18, 2008 | 11:11 PM
eddy_dee's Avatar
wat size turbo should i run?
Old Sep 18, 2008 | 11:15 PM
jasony0630's Avatar
76.26.106.124
a precision T88.
You'll do great!
Old Sep 18, 2008 | 11:32 PM
eddy_dee's Avatar
Default Re: (jasony0630)
where can i find one at?
Old Sep 18, 2008 | 11:38 PM
cmgibby's Avatar
eddy_dee
w/ your swap; what injectors did you use; ECU?
also did you use pwr steering and/or A/C??
Old Sep 18, 2008 | 11:57 PM
eddy_dee's Avatar
Default Re: (cmgibby)
no p/s or a/c
SRDFTITAN
Jun 8, 2014 09:02 AM
jdm-judah
Jan 11, 2008 09:12 AM
JDM_Acccord
Jul 5, 2007 03:24 AM
GroundZer0 336
Jul 13, 2003 07:15 PM
Andrew 825SM
Oct 2, 2002 07:39 PM
