Sparks plugs stick out like a cm. except for one *pics
Looks like theyre not pushed down all the way. Make sure the connectors arent bent or anything. you should hear/feel them 'click' into place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos »</TD></TR><TR><TD CLASS="quote">Looks like theyre not pushed down all the way. Make sure the connectors arent bent or anything. you should hear/feel them 'click' into place.</TD></TR></TABLE>
+1
+1
ya i click them into place and then when i drive they pop back up. there the right size and everything...
ok. i actually did this yesterday. listen closely. the wire running through the middle is seperate from the boot. hold the wire close to the boot with one hand and try to work the boot to where it should be. so just push on that and hold the wire. problem solved.
