Sparks plugs stick out like a cm. except for one *pics
Old 09-17-2008, 12:53 PM
wdissident's Avatar
Default Sparks plugs stick out like a cm. except for one *pics
3 of my spark plugs pop out more then one. the 3 to the left all stick out and the 4th just stays intact, it starts and everything, i did get new wires because my old ones were cheap, and a new distributor, i was just curious.
Old 09-17-2008, 01:20 PM
alphalanos's Avatar
Default Re: Sparks plugs stick out like a cm. except for one *pics (wdissident)
Looks like theyre not pushed down all the way. Make sure the connectors arent bent or anything. you should hear/feel them 'click' into place.
Old 09-17-2008, 02:50 PM
ten2doyle102's Avatar
Default Re: Sparks plugs stick out like a cm. except for one *pics (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">Looks like theyre not pushed down all the way. Make sure the connectors arent bent or anything. you should hear/feel them 'click' into place.</TD></TR></TABLE>
+1
Old 09-17-2008, 11:31 PM
wdissident's Avatar
Default Re: Sparks plugs stick out like a cm. except for one *pics (ten2doyle102)
ya i click them into place and then when i drive they pop back up. there the right size and everything...
Old 09-17-2008, 11:47 PM
k7q
k7q's Avatar
maybe your spark plug isnt tighten? happened to me once.
Old 09-18-2008, 01:01 AM
wdissident's Avatar
Default Re: Sparks plugs stick out like a cm. except for one *pics (k7q)
how do i tighten it? lol
Old 09-18-2008, 01:02 AM
Hanmin's Avatar
5/8th deep socket
Old 09-18-2008, 05:15 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Default Re: (Hanmin)
Mine old d series used to do that all the time. I think I eventually figured out it was cheap crappy wires that weren't sealing right.
Old 09-18-2008, 06:48 AM
davefromPA's Avatar
Default Re: (Vindicator9000)
ok. i actually did this yesterday. listen closely. the wire running through the middle is seperate from the boot. hold the wire close to the boot with one hand and try to work the boot to where it should be. so just push on that and hold the wire. problem solved.
Old 09-18-2008, 10:52 AM
wdissident's Avatar
Default Re: (davefromPA)
hmm. i got carquest wires. those crappy. cus the ones before that weren't from Honda n those were crap and still popped up.
Old 09-18-2008, 11:33 AM
davefromPA's Avatar
Default Re: (wdissident)
the only reason i said that is cause i did it yesterday.
hondadc2
08-07-2008 11:37 AM
Tegraracer90
10-24-2007 12:19 PM
Iomega01
10-16-2005 09:43 PM
matman4444
07-06-2005 10:15 PM
VinceVTEC
02-15-2004 07:36 PM
Quick Reply: Sparks plugs stick out like a cm. except for one *pics
