Anybody ever use this amp... Any good?
Sound Storm Force 400 Watt 4-channel Amp: 4F400
specs:
RMS Power at 4 Ohms 50 W x 4
RMS Power at 2 Ohms 100 W x 4
Anybody ever used this amp/ brand of amps?
P.S. before anybody makes any smart comment, I know you get what you pay for but I'm broke and need an amp to power my eclipse sp6510 components atleast temporarily. Also I currently own a poweracoustics 2ch 480 watt amp
spec:
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 100 watts x 2 channels
RMS Power (2 ohms) 125 watts x 2 channels
RMS Power (1 ohm) N/A
Bridged RMS Power 250 watts x 1 channel
Total RMS Power 250 watts
Peak Power Output 480 watts x 1 channel
Total Peak Power 480 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.02%
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP)
High-Pass Crossover Frequency 50 - 500 Hz
Low-Pass Crossover Frequency 30 - 500 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 98 dB
Channel Separation 55 dB
Bass Boost 0 - 24 dB
Bass/Gain Remote No
Fan Cooled No
Fuse Rating 15A x 2
Could I use this to power my components?
Modified by Allurian at 11:06 AM 9/17/2008
Modified by Allurian at 11:15 AM 9/17/2008
specs:
spec:
Amplifier Class AB
Subsonic Filter N/A
Bass/Gain Remote No
Fan Cooled No
Fuse Rating 15A x 2
In a friend's F-150, he replaced a CRUNCH with some sort of SoundStorm, about those specs. I am pretty sure the amp is no longer functional. After a month or so the subs started popping (JL 10's) and being overall odd. We re-wired everything and such, no avail. Replaced amplifier and went away.
It was a good amp for the first month, though. Hit pretty cleanly for being a Fry's special. Be sure to get some sort of warranty though if you do get it!
Thanks for the input from both of you.. I think I might just use my two channel.. I was worried at first it would be too much for my components
Ahh, I just got information from the F-150 owner concerning this.
" it was really old, years old when i got it like two years ago"
Okay, so they last a good bit of time, he seemed to have one of the oldschool Sound Storm amps. But eh, I'm unsure. That's all the input I have.
