need help with engine build ( ls-vtec )
hey guys im going to build a ls-vtec... my b16a block is completly shot..the mounthing point for the int med shaft is broken...and the rings are fried..
i just wanted to know... if i should use the pr3 pistons and get new rings..
or use the pr4 pistons that are newer and in mint shape...
i have taken the pr3`s out and aswell as the crank.... what do you think i should do?... the pr3 pistons are still in good shape aswell...
From: Where the wild things are in, NY, United States of America
Try the all motor forum. If a machinist says they check out... just use the ones that get you closest to the specs / CR you're looking for.
dpine
Sep 22, 2008 03:42 PM
