hondata hook up
Old Sep 16, 2008 | 08:42 PM
gsr_88_crx's Avatar
Default hondata hook up
how do i hook up my hondata s300 and b18 wiring harness in my 88 crx? right now the ecu isn't getting power? appretiate any help
Old Sep 16, 2008 | 09:38 PM
thorclark's Avatar
you have to solder the s300 into the ecu.
Old Sep 17, 2008 | 05:59 PM
gsr_88_crx's Avatar
Default Re: (thorclark)
its already been soldered in. the ecu worked in my 97 hatch. i just dont know what to wire? i have the main wire coming out of the wiring harness connected to the fuse box under the hood. is there more wires to be connected?
Old Sep 17, 2008 | 07:39 PM
thorclark's Avatar
Default Re: (gsr_88_crx)
is you car obd1?
Old Sep 17, 2008 | 08:36 PM
gsr_88_crx's Avatar
i dont thnk so....its a 1988. the ecu was hooked up in a 97 civic.
Old Sep 17, 2008 | 08:57 PM
gsr_88_crx's Avatar
dont u have to use a obd1 ecu with hondata also?
Old Sep 18, 2008 | 10:21 AM
sgallagher's Avatar
You must convert to OBD1. Just changing the ECU will NOT work.
Get a OBD0-OBD1 jumper and change distributor and you'll be good.
Old Sep 18, 2008 | 01:41 PM
gsr_88_crx's Avatar
Default Re: (sgallagher)
wait...sowill myecu and wire harness i have in the car now work with this jumper? how come the distributor will not work?
Old Sep 19, 2008 | 07:32 PM
thorclark's Avatar
ok you need a obd1 ecu with s300 soldered in. Then you need a obd0-obd1 jumper harness. obd1 Dizzy Also a 4 wire 02 sensor
CRX91SE
May 16, 2011 05:46 PM
teg4life
Sep 22, 2004 12:28 PM
GDM Z28
Apr 9, 2004 10:40 PM
275Performance
Dec 18, 2003 07:23 PM
jaydmcrx
Nov 24, 2003 10:22 AM
