Del Sol into Civic Radiator Hose Choices
Old Sep 16, 2008 | 07:40 PM
florida's Avatar
Default Del Sol into Civic Radiator Hose Choices
I am planning to swap a DOHC VTEC Del Sol Radiator into my 99 Civic EX (acura EL really, but it's the same as a 99 Civic EX) with a D16Y8. I understand this is a bolt in part, but that my SOHC hoses will be too small for the radiator outlets. Please feel free to correct me if I'm wrong.
1. Would I be better off going with DOHC hoses and clamping them down tightly on my engine; OR going with stock SOHC lines and stretching them onto the radiator outlets?
2. What year and model DOHC hoses should I use, if I use them?
3. If I clamp them down, I understand that I should use a threaded clamp. Is the picture below the correct type of clamp?
Thank you very much. I searched a good amount and didn't see a clear answer.
Old Sep 16, 2008 | 07:41 PM
Hanmin's Avatar
i threaded mines down, no problems here, looks kinda poofy if you know what i mean.
Old Sep 16, 2008 | 07:54 PM
94EG8's Avatar
Seagull Management
Default Re: Del Sol into Civic Radiator Hose Choices (florida)
Not sure if you can get the smaller hoses to stretch that much and de sol hoses fit different due to where the outlet on the head is. Honestly it would probably be a lot easier to just get a stock replacement rad, no screwing around. If you're doing this because you think you need a bigger rad, you need to have quite a bit of work done before you need to start thinking about a bigger rad, stock rad will even cool a GS-R engine just fine.
Old Sep 16, 2008 | 07:55 PM
florida's Avatar
You used the larger hoses and then used threaded clamps on the engine side of the hose?
del sol1658
12
Nov 20, 2006 06:02 PM
the soL that could
12
Mar 25, 2006 03:58 AM
Mr. JDM-GSR
Feb 9, 2006 05:30 AM
delsolrob
10
Apr 27, 2004 08:57 PM
phantom_sol
10
Apr 28, 2003 05:53 PM
