97 dx coupe IAT wiring help
i put an OBD1 motor in my 97 dx coupe, and kept the origional harness. a friend switched it from the obd2 sensor in the intake arm and spliced in the 2 wire sensor for sensor type on the intake arm.
anyways im throwing the code10
i changed the sensor to a brand new one and reset the ecu, now im trying to track down the wiring. i just need to know for sure for 96-98 what the wire color codes are
one wire is red/yellow
what is the other wire? green/white or what? lol my only code!!!
Sweet thanku, somehow my iat is connected to a black/yellow, but only throwing code 10 on my chipped p28, is black yellow for an obd2 sensor then?
Modified by Drew17th at 12:48 AM 9/17/2008
well I wired it to green/black and reset the edu and still no luck, any ideas? Already replaced the sensor with a brand new one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th »</TD></TR><TR><TD CLASS="quote">Sweet thanku, somehow my iat is connected to a black/yellow, but only throwing code 10 on my chipped p28, is black yellow for an obd2 sensor then?
Modified by Drew17th at 12:48 AM 9/17/2008</TD></TR></TABLE>
If you had your IAT connected to a black yellow thats normally 12v, the IAT is quite a bit lower 5v? I think, they die a pretty much instantanous death when connected to 12v.
yea still checks good tho, only thing I can think of is run all new wires and tie it into wires by the ecu. I'll just tie into red/yellow and green/black? Should this hopefully take care of it? This is killing me haha, one code and I can't shake it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th »</TD></TR><TR><TD CLASS="quote">yea still checks good tho, only thing I can think of is run all new wires and tie it into wires by the ecu. I'll just tie into red/yellow and green/black? Should this hopefully take care of it? This is killing me haha, one code and I can't shake it!</TD></TR></TABLE>
It should, if it doesn't either the sensor is bad or something in the ECU burnt.
