MY K20A3 GRINDS INTO THIRD AND SLIPS OUTTA THIRD :(
so i have a ep3 and it slips out of third when in the low rpms just cruisin in the neighborhood and ****, but it also grinds really bad when around 5800 on the rpm...i dont know much about transmission so could someone please please tell me what i need to do to fix this..my guess is its something to do with the gear box or something....HELP!!! PLEASE!!
Could be a few things.
1. Countershaft or mainshaft bearing has a lot of play.
2. Synchronizer sleeve is beat to ****.
3. Gear is worn really, really badly.
You simply won't know until you get it pulled apart unfortunately.
Good luck.
p.s. And change/check the transmission fluid. Replace it if necessary and fill it up with the proper amount.
Good luck.
# 2 possibly compounded by the gears "dogs" being round asd [freak]. The syncros usually hold up better than the selector sleeves
Honda/Acura has a Service Bulletin on the 3rd gear synchro hub assembly (updated part 3rd gear hub assembly) this is a pretty common thing for the gearbox, Go to your local dealer and see if you are still covered under warrany if not talk to the manager and see if you can get a Goodwill from Honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin »</TD></TR><TR><TD CLASS="quote">Honda/Acura has a Service Bulletin on the 3rd gear synchro hub assembly (updated part 3rd gear hub assembly) this is a pretty common thing for the gearbox, Go to your local dealer and see if you are still covered under warrany if not talk to the manager and see if you can get a Goodwill from Honda.
x2
</TD></TR></TABLE>x2
HondaRcB
Nov 24, 2006 11:41 AM
RockLee`
15
Nov 1, 2005 12:41 PM
Rpizzle
Apr 11, 2005 03:24 PM
