car whines in all gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia »</TD></TR><TR><TD CLASS="quote">second gear whine is common even after the 2nd gear jet kit.</TD></TR></TABLE>
I'm assuming the OP is talking about his 95 5 speed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 »</TD></TR><TR><TD CLASS="quote">When was the last time you changed the fluid?</TD></TR></TABLE>
Have you at least checked the fluid level?
FYI. Every 24months or 30,000 Miles (witch ever comes first) is when you should change your manual trans oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord »</TD></TR><TR><TD CLASS="quote">
FYI. Every 24months or 30,000 Miles (witch ever comes first) is when you should change your manual trans oil.</TD></TR></TABLE>
That and if it was changed recently what was it filled with. If he put gear oil in that trans is toast.
I'm assuming the OP is talking about his 95 5 speed</TD></TR></TABLE>
dam it ross i just caught that my self i have auto on the brain last night i need to lay off the monsters
From: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
The whining it isn't your tranny, we know that the MILF riding shotgun is the NANNY!
Sorry, could not resist.
In my day and in my 63 Impala it was a bearing.
What is this using 30 weight oil? WHat happened to 80w MT oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bad Brian »</TD></TR><TR><TD CLASS="quote">Johnlear, is that New South Wales? Any AWD Orthias there you can send me?</TD></TR></TABLE>
Brian,
Yes, and, what's an "AWD Orthia"?
Brian,
(Brian,
Yes, and, what's an "AWD Orthia"?)
It is a essentially a 1996 and up Civic wagon, some are AWD, sold in Japan, N.Z. but I guess not Aus.
Recently when I changed the fluid. I changed it twice in a month to see if that would fix it. First time 10w 30, second time Honda MTF. It went in yellow and came out sorta grey, both times. I know its not a good sign. Seems like 5 speed trans is getting worst day by day. Anyone have a h23 or f22 tranny for sale?
I am not an expert on Tranny's, I like real women but that sounds like you have metal shavings in the oil and it is dirty WAYYYYYYYY too fast. There is a thead at this site just on tranny issues, go there.
