ARP head stud install question
Mine stuck up a little higher too. After doing a little research I found that everyone else had the same issue. Well actually its not really an issue. Itll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">check and see i it's beginning to cross thread</TD></TR></TABLE>
If it was cross threading he wouldn't be able to get it in there at all..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker »</TD></TR><TR><TD CLASS="quote">
he didnt say it was in all the way, just hand tight. hand tight can be cross threaded. back on topic
</TD></TR></TABLE>he didnt say it was in all the way, just hand tight. hand tight can be cross threaded. back on topic
Yea I am not cranking them with the allen or anything it goes in like butter all the way then stops like this is all it has but sticks up about 1/4 inch maybe a tad more then the rest of them, this is on a d16z6 on the back corner near number one or the side closest to the trans. So this is normal anyone else clarify this? I do not think it is cross threading I know what that is like.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan »</TD></TR><TR><TD CLASS="quote">It's normal. Just follow the instructions for installation and your golden.
Sweet thanks man, this is going in a 89 sedan btw
</TD></TR></TABLE>Sweet thanks man, this is going in a 89 sedan btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatblkguy »</TD></TR><TR><TD CLASS="quote">Did you clean the threads in the block with break clean? I had the same issue on my B18 </TD></TR></TABLE>
yeah i was thinking the same. i bought a used block years ago and it was gunk built up in there. you could here it as i turned
skiracer8148
11
Aug 14, 2007 07:59 PM
