ARP head stud install question
Old Sep 16, 2008 | 05:51 PM
Deano_D aka
Default ARP head stud install question
I am putting ARP head studs into my d16z6 and I noticed the the rear stud on #4 seems to sit higher at hand tight I do not think this is normal.. Am I right?
Old Sep 16, 2008 | 06:00 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
check and see i it's beginning to cross thread
Old Sep 16, 2008 | 06:07 PM
eh3 93's Avatar
Default Re: (HybridcivicLS-T)
Mine stuck up a little higher too. After doing a little research I found that everyone else had the same issue. Well actually its not really an issue. Itll be fine.
Old Sep 16, 2008 | 07:36 PM
Deano_D aka
Default Re: (eh3 93)
yea all of the are flush but this one is about 1/4 maybe 1/2 inch higher.
Old Sep 16, 2008 | 07:49 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">check and see i it's beginning to cross thread</TD></TR></TABLE>
If it was cross threading he wouldn't be able to get it in there at all..
Old Sep 16, 2008 | 08:02 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">
If it was cross threading he wouldn't be able to get it in there at all.. </TD></TR></TABLE>
he didnt say it was in all the way, just hand tight. hand tight can be cross threaded. back on topic
Old Sep 16, 2008 | 08:06 PM
Deano_D aka
Yea I am not cranking them with the allen or anything it goes in like butter all the way then stops like this is all it has but sticks up about 1/4 inch maybe a tad more then the rest of them, this is on a d16z6 on the back corner near number one or the side closest to the trans. So this is normal anyone else clarify this? I do not think it is cross threading I know what that is like.
Old Sep 16, 2008 | 08:24 PM
90sedan's Avatar
Default Re: (Deano_D aka "Brick Top")
It's normal. Just follow the instructions for installation and your golden.
Old Sep 16, 2008 | 08:33 PM
Deano_D aka
Default Re: (90sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan &raquo;</TD></TR><TR><TD CLASS="quote">It's normal. Just follow the instructions for installation and your golden. </TD></TR></TABLE>
Sweet thanks man, this is going in a 89 sedan btw
Old Sep 17, 2008 | 06:10 AM
thatblkguy's Avatar
Did you clean the threads in the block with break clean? I had the same issue on my B18
Old Sep 17, 2008 | 06:12 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (thatblkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatblkguy &raquo;</TD></TR><TR><TD CLASS="quote">Did you clean the threads in the block with break clean? I had the same issue on my B18 </TD></TR></TABLE>
yeah i was thinking the same. i bought a used block years ago and it was gunk built up in there. you could here it as i turned
Old Sep 17, 2008 | 07:58 AM
thatblkguy's Avatar
Yep same here cleaned them all out and they fit like a glove
projectef
Nov 7, 2008 12:15 PM
skiracer8148
11
Aug 14, 2007 07:59 PM
freddysEF
May 23, 2007 01:26 PM
ilikejesus
Mar 29, 2007 06:03 PM
specv5150
Aug 6, 2005 06:30 PM
