93 EG6 Si-Gsr Swap
Ok so I have a 1993 Civic Si with a z6 right now. Im doing a GSR swap this friday and This is what I have
Gsr Longblock,Gsr Dizzy,Transmission Hydraulic,full wiring harness,p72 ecu,gsr mounts and a Hasports tranny Mount. Now Am I missing anything for the swap also can i use the stock throttlebody cable and oh yes I have Gsr Axles and half shaft. So let me know what im missing for the swap and what I can use from my old parts.
you need a GS-R throttle cable. Also you will need to wire the knock sensor, If you have a standard left hand drive GS-R harness then you can use that, but you will still have to run a wire from wherever the knock sensor wire ends on the engine harness (would be at a shock tower plug I assume) to the ECU. you will also need to wire up the IAB if you would like them to function, this is optional.
TheMostSadistic
Apr 24, 2003 11:15 AM
