Tial 38mm Wastegate question!!!
ok so i got a brand new tial 38mm wastegate, my question is, is that i am going to run the vac line to the compressor of the turbo.....cause my t3 already has the fitting on it, i read on H-T Turbo FAQ that if you run it to the compressor you will see like 2psi drop at the motor, so i have a 5psi spring in it now and i cant decide if i should get either
.70 bar/10.15psi which you if H-T is true would be LIKE 8psi at the motor which i want! OR
.60 bar/8.70psi and if H-t is true would be like 6psi
I want around 8psi at the motor which is a JDM D15b
can anyone let me know what they think thanks
OR should i just get a boost controller?
I guess the theory is that since your pulling a pressure source before the intercooler and all of the piping, that the 5 psi would be reached first than it would at the intake manifold. If you want a true 8 psi then I would pull a pressure source off of the intake manifold. Make sure that the signal line is a clean source. Teeing (if that's even a word) off of one vac line for several different sources is not a good idea. I drill and tap my intake directly and have one vac line for each acc. Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowB16si »</TD></TR><TR><TD CLASS="quote">I would plug the compressor and get a source from the intake manifold.</TD></TR></TABLE>
completely ignoring the instructions that came with the wastegate
Don't use the intake manifold as the source. The best place to get your source from is the cold side of the IC piping. On my car I welded a -4 bung on the cold side of the IC end tank.
Exhaust backpressure also plays a huge role in actual boost pressure with a given spring. The pressures TiAL gives are based on a 1:1 pressure ratio. If you have a small turbo then you're likely to get less than "spring pressure" and if you have a big turbo you can easily get more than "spring pressure".
Run it with the small spring and see where it goes. You can always turn it up with a boost controller, can't turn it down w/o changing the spring.
ok thanks guys, i think ill just run it from the compressor to make my life alot easier....and use a boost controller to play with the boost to get it to where i want when i tune my car..
Vagitarian
Jan 6, 2013 05:34 PM
EJ1 wilcox
Jul 1, 2005 07:57 AM
