B16a2 into 1997 Coupe with D16 - HARNESS questions and IMOBILIZOR
Dear All,
I'm swapping my D16y8 on a 1997 coupe.
It has obd2a harness.
The motor its from 2000. Obd2b, BUT I MANAGED TO GOT A obd2a ECU
Question 1 :
- I have the Obd2a hardness from D16y8 Vtec.
- I have the obd2a ECU from a B16a2
- Can i use this harness? Or do i also need a obd2a harness from a B16a2 because of knock sensors?
Question 2:
- I had a great deal and i've buyed a P30
- I also have Obd2a to Obd1
- The motor mounted its the B16a2 obd2
- The harness its obd2a also, but its from a D16
- Can use this setup? Or am i missing knock vtec sensors? Do i also need the b16a2 obd2a harness?
Mainly my question is: If you have a D16Y8 Obd2a harness. Can you use it on B16a2 obd2 motor and obd2a B16 ECU? Or do you need the trully harness from a B16 obd2a because of some vtec sensors?
Question 3:
- Whats the CKF trick? Do i need it?
Question 4:
- Can i use my imobilizor? Or can i swap it (unsold / sold) from my original obd2a D16 ECU to the obd2a B16 ECU?
Question5:
- How can i bypass the imob if i change ECU since the ECU its from the original motor? Everything its obd2a
Question 6:
- If i use the P30 with conversion obd2a to obd1
- What are your tips ?
Question 7:
- Im going to put a B18c5 distributor from a ITR
- The motor will be a B16a2 from 2000
- The harness is obd2a
- I've looked closer and it looks plug and play. Do i connect it? Or do i need some change?
Thank you very much for your support
Question 1 :
Question 2:
Question 3:
Question 4:
Question5:
Question 6:
Question 7:
engrish is choppy but i'll help
everything should plug up on the new engine
which obd2a ecu did you get?
p30 if obd1 would definately be better than any obd2 ecu. personally i'd get a hondata s300 for tuning options.
i'm pretty sure your car does not have an immobolizer
only wire in your harness you'll be missing is KNOCK but if you convert to obd1 with chipped ecu you don't NEED a knock sensor.
if you have any more questions just post them here
Thanks for the help.
I will most probably go with the P30 and harness conversion from obd2a to obd1.
That was the point. I wanted to know if there was some sensor missing from a D16y8 to a b16, even when they are both obd2a harness.
Any idea how to connect this sensor if i wanna stick in the obd2a b16 ECU?
get the knocksensor plug on the engine harness side....run a wire into the ecu and pin it in the correct location
Any idea where this sensor is? It must be the only one i dont have harness on the motor for it. eheheh
But any idea?
But any idea?
all the d16y8 harness have a knock sensor plug on it so you dont have to do anything to the harness unless youre using a b-series motor
if you gonna use a b-series motor have make a few wires longer (vtec,vtec pressure switch)
Yes im going to use a B16 motor with the D16y8 harness.
Can you be more specific on what i need?
Thanksss!!!!!
Thanksss!!!!!
just make 3 wires longer
vtec wire its green/yellow
vtec pressure switch wires one is blue/black and the other is black
everything else is plug and play
and by the way if you have a iat sensor on the intake manifold (its a white sensor on runner 1 or 2 of the intake) youll have to cut the plug off on your harness (its a black plug that plugs up to the black sensor that go's in the intake tube) and find a round 2 wire plug add some wire and you good to go
justinmaccc
Oct 18, 2015 11:10 AM
Vapochilled
Sep 16, 2008 09:09 AM
oneforce
Apr 24, 2006 10:21 AM
v-tec maz
Dec 31, 2005 04:29 PM
