Transmission & Drivetrain Gearboxes, Differentials, Clutches
transmission problem
Old Sep 15, 2008 | 06:19 PM
95_red_dc's Avatar
Default transmission problem
I am in middle of rebuilding my b18c1 with the stock transmission from my gsr. I have the fidanza flywheel and competition stage 4 clutch all brand new. I am having a problem with getting the transmission to bolt up it wont go all the way in it stops about 1/2 inch from the block. Has any one had this problem before? what should I do?
Old Sep 15, 2008 | 07:09 PM
Aquafina's Avatar
Turn the flywheel until the mainshaft splines line up with the clutch hub.
Old Sep 15, 2008 | 07:22 PM
95_red_dc's Avatar
Default Re: (Aquafina)
I've been trying that just I was turning the transmission shaft instead of the flywheel and clutch. I don't if that makes a difference or not
Old Sep 15, 2008 | 07:26 PM
Aquafina's Avatar
Have to pull the trans away to spin the mainshaft so its hard to line it up that way. Spin the flywheel with the trans in place.
Old Sep 15, 2008 | 07:33 PM
95_red_dc's Avatar
OK I'll give it a try tomorrow after I get off work thanks for the tip
Old Sep 15, 2008 | 11:03 PM
Aquafina's Avatar
No problem. Its easier to do if you have someone to help the first time or two.
BROCKMYSTER
May 8, 2010 06:49 PM
milanoteg
Mar 19, 2010 02:52 AM
Mr.Luder
Jul 11, 2007 12:01 AM
incredteg3
Feb 11, 2005 06:24 PM
gsf4726
Jan 15, 2004 10:00 AM
