Flywheel problem?
Old Mar 6, 2010 | 12:41 PM
milanoteg's Avatar
Default Flywheel problem?
1998 Integra GSR, stock for the most part.
RECENTLY i've noticed my clutch will slip under WOT. It won't slip anytime else, like normal driving conditions, only under full throttle. My clutch has plenty of meat left on it. The only thing I've done recently to my car was a new CMC. I had a shop install it, maybe this has something to do with it? Or is my flywheel conveniently going up?
Any suggestions would help, thanks in advance.
Old Mar 6, 2010 | 12:45 PM
TheAsian's Avatar
Default Re: Flywheel problem?
Your clutch is failing, thats all their is to it. Disc is worn out or pressure place springs are worn. A master or slave wont cause issue like that.
Old Mar 6, 2010 | 12:53 PM
milanoteg's Avatar
if that's the case, is there any way around replacing clutch+flywheel? or should i just bite the bullet and do it
Old Mar 6, 2010 | 12:54 PM
racebum's Avatar
agree
buy a new clutch kit and be done with it
if your flywheel is warped out of true it also could be promoting this since the clutch face would never sit flush against the disc. even if this is the case, get a new clutch since you will have beat the hell out of yours with the warped flywheel.
Old Mar 6, 2010 | 12:56 PM
racebum's Avatar
there are inexpensive ways to bite the bullet
http://cgi.ebay.com/ebaymotors/EXEDY...#ht_2667wt_933
this is actually a great kit for 180-190whp or less that does not use slicks.
Old Mar 6, 2010 | 12:58 PM
milanoteg's Avatar
Funny thing is that I had bought a clutch kit a few weeks ago but the problem turned out to be the CMC so I returned it. Figures once I return it my clutch starts to slip fml
Old Mar 6, 2010 | 01:01 PM
racebum's Avatar
it happens but in your case replacing the flywheel is also a great idea.
that deal from gripforce i posted is the best price to quality deal i know of for a full replacement.
Old Mar 6, 2010 | 02:50 PM
TheAsian's Avatar
You can resurface the flywheel and pressure plate depending on condition. And get a new organic disc.
But I would just sug replacing the clutch and resurfacing the flywheel.
Old Mar 6, 2010 | 08:15 PM
racebum's Avatar
how in the world could you resurface the pressure plate? the lathe would hit the side mounts
Old Mar 6, 2010 | 11:26 PM
TheAsian's Avatar
W/ the proper Attachments you can attach the pressure plate using the mounting bolts for the flywheel in a reverse pattern.
I've only did it at the school I went to, and Ive heard for only a few shops actually performing that work but it is possible to do.
Old Mar 6, 2010 | 11:47 PM
DCRB's Avatar
why though? new clutch's come with new pressure plates for a reason...
Old Mar 7, 2010 | 08:58 AM
milanoteg's Avatar
Yeah I'm just going to buy a new kit
Old Mar 7, 2010 | 09:13 AM
GagnarTheUnruly's Avatar
I have basically the same kit and it's a great deal. Should last +60-70k and the flywheel improves performance noticeably. Hard to beat for $250.
Old Mar 7, 2010 | 09:16 AM
milanoteg's Avatar
Yeah the kit I had bought previously was $220, but didn't come with a flywheel. I'm assuming my flywheel is in decent enough shape to resurface, but hell for $30 more might as well get a brand new one.
Old Mar 7, 2010 | 09:19 AM
Stock flywheel can be resurfaced if it isn't too bad, but aftermarket flywheels can't. But IMO the light flywheel is worth every penny from a performance standpoint.
Old Mar 18, 2010 | 07:02 PM
milanoteg's Avatar
Do you think it might be how the CMC was adjusted? The clutch engagement point is REALLY high off the floor.
If this 100% can't be the problem, it's definately my clutch going up, because it's slipping more regularly.
Old Mar 19, 2010 | 02:52 AM
milanoteg's Avatar
bump for opinions
bank2me
Jun 5, 2011 02:13 PM
incubus
Apr 14, 2008 07:29 PM
kkw103
Oct 27, 2006 12:14 PM
gsf4726
Jan 15, 2004 10:00 AM
BigBadBuford
Oct 22, 2003 08:34 AM
