Home insulation in car ok?
Old Sep 15, 2008 | 04:56 PM
lv6l's Avatar
Default Home insulation in car ok?
I been having the idea of filling my rear side panels inside my 94 civic hatch with the yellow insulation you would find in your attic. Question is, I am not a professional when it comes to insulation, I tried searching but no luck, does anyone know if it's safe to put it in your car, I've herd it's not so good to breath in and was not sure if the material will leak into the cabin after I insulate it between my body of the car and the rear side panels. Thanks.
Old Sep 15, 2008 | 04:57 PM
importdreamer's Avatar
Default Re: Home insulation in car ok? (lv6l)
why?
Old Sep 15, 2008 | 04:58 PM
BryanM.'s Avatar
Resident Gearhead
To reduce sound/road noise? There are other ways around this...
Old Sep 15, 2008 | 05:05 PM
Bad Brian's Avatar
From: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
Default Re: Home insulation in car ok? (mcvtec)
it will probably trap moisture
Old Sep 15, 2008 | 05:08 PM
lv6l's Avatar
I am doing this to reduce road noise. I know there is other way around this, but wouldn't hurt to ask if the material is on hand and would not cost me much.
What other method do you guys think for reducing road noise that is affordable.
Old Sep 15, 2008 | 05:20 PM
g0rg0n's Avatar
Default Re: (lv6l)
Find an old Caddy and pull the padding out from under the carpet. It kills sound and is cheap.
Old Sep 15, 2008 | 05:28 PM
nix94delsol's Avatar
Default Re: (g0rg0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0rg0n &raquo;</TD></TR><TR><TD CLASS="quote">Find an old Caddy and pull the padding out from under the carpet. It kills sound and is cheap. </TD></TR></TABLE>
thats what im doing
but with an 02 benz
Old Sep 15, 2008 | 10:19 PM
lv6l's Avatar
How cheap are we talking about and where do I go and get it?
Old Sep 15, 2008 | 10:44 PM
slomofo's Avatar
GDD Member
Junkyards shouldn't charge you more than $10.00. Do you have a salvage type store in your area?
We've got this place where I am called NPS that takes all that crap that falls off of shipping trucks and sells it to the public, but the only downside is nobody knows what most of the crap is, so you have to know what you're looking for. I usually find dynamat in there for like $2.00 a box.
http://www.npsstore.com/display.asp
See if you've got one of these salvage stores around and go check it out, you might find some quality sound deadening material that was made for cars that's very inexpensive.
Old Sep 15, 2008 | 10:52 PM
likwid2u's Avatar
you do realize the home padding stuff is fiberglass right? tat stuff is going to make you itch if wind gets a hold of it some how
Old Sep 15, 2008 | 11:02 PM
slomofo's Avatar
GDD Member
Default Re: Home insulation in car ok? (likwid2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likwid2u &raquo;</TD></TR><TR><TD CLASS="quote">you do realize the home padding stuff is fiberglass right? tat stuff is going to make you itch if wind gets a hold of it some how</TD></TR></TABLE>
I think he's referring to the foam insulation, not the pink stuff.
Old Sep 16, 2008 | 10:14 AM
lv6l's Avatar
I have junkyards, I probably will go check there. Is the padding underneath the carpet machine washable, because when I get it I'm pretty sure it's going to smell pretty foul.
Old Sep 16, 2008 | 10:51 AM
alphalanos's Avatar
Default Re: (lv6l)
Or you can get something like Ensolite. Adhesive sound deadener.
Old Sep 16, 2008 | 11:08 AM
carlosacasa26's Avatar
we don't just give titles out
Cool, I need to try this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">I have junkyards, I probably will go check there. Is the padding underneath the carpet machine washable, because when I get it I'm pretty sure it's going to smell pretty foul.</TD></TR></TABLE>
*Bump* (for same question)
96civicexrican
11
Oct 15, 2008 02:26 PM
civic-cpe
Honda Civic (2006 - 2015)
Dec 12, 2007 01:34 PM
JLEK
Audio / Security / Video
May 24, 2007 10:08 PM
eL
Dec 19, 2004 09:31 AM
nek0
Apr 25, 2003 09:23 PM
