Removable Noise Dampering Materials?
Old May 21, 2007 | 10:21 AM
JLEK's Avatar
Default Removable Noise Dampening Materials?
Hey guys I've really considering adding a bit of noise dampening material in my 1996 Civic Hatch. However Dynamat, B-Quiet, etc seems like they will be a pain to remove down the line. Are there any noise dampening material we can use on our car that can be easily removed?
Modified by JLEK at 11:42 AM 5/21/2007
Old May 24, 2007 | 07:36 PM
MilanoCivic97's Avatar
Default Re: Removable Noise Dampening Materials? (JLEK)
no.
Old May 24, 2007 | 08:48 PM
imadigitalgod's Avatar
if it was easily removed, it wouldnt be a very good dampening material
Old May 24, 2007 | 09:54 PM
JLEK's Avatar
it doesnt have to be too good.. anything is better than nothing.. just have to dampen the noise a little right now i have some carpet padding under the rear seat and spare tire well and its a bit quieter.
Old May 24, 2007 | 10:08 PM
chrisw85's Avatar
If you want to dampen road noise moreso than panel vibrations, then a closed cell neoprene type of material may suit you. Butyl rubber is good at deadening vibrations of whatever it is bonded to. Neoprene rubber/closed cell foam should still cut down road noise even if its not in full contact with whatever panel you are trying to quite down. You can buy the stuff w/o adhesive backing and just parhaps 'spot glue' certain points.
kcari
Suspension & Brakes
Oct 28, 2009 12:30 PM
Outrun
13
Jul 16, 2004 05:50 PM
