apex v-afc reading tach wrong
Old Jul 25, 2002 | 05:01 PM
mntdewred's Avatar
Default apex v-afc reading tach wrong
i recently installed the v-afc (about 2 hours ago), did all the initialization parts, started the car, everything monitored fine. the dash tach said the same as the v-afc tach. now after shuttin down and restarting, the v-afc tach is off and off by a good amount.
at idle, the v-afc states 450; dash states 600
4th gear, dash 3k; v-afc 1900
what could be the problem? i didnt change anything yet; but say i did and wanted to go back to factory settings, i would just go to 'etc.' and 'initialization' and say 'yes' right?
thanks again
Old Jul 25, 2002 | 07:31 PM
turbologist's Avatar
Default Re: apex v-afc reading tach wrong (mntdewred)
yes to resetting ur settings. As far as ur tach reading be so far off. You start ur car n check the settings when u see that ur tach and the afc's tach dont match. Go to settings and see if u have the correct 6 in 6 out i believe for ur car (just check the manual that comes with it) If this is ok make sure that its set to 4 cyl. and then make sure that its hooked up properly. You might have a bad connection or a wrong connection somewhere. Just be thourough with everything. HTH
Old Jul 25, 2002 | 11:14 PM
erniecars's Avatar
Default Re: apex v-afc reading tach wrong (drealboostedhybrid)
I bet you have the rpm wire that supposed to be hooked up to an ignition wire on the ecu hooked up to the speed sensor instead.
Old Jul 26, 2002 | 12:15 AM
kinesistech's Avatar
Default Re: apex v-afc reading tach wrong (erniecars)
Normal. Every vafc doesnt match the stock tach. Neither does an Autometer tach. Stock one sucks.
Try monitering VTi and rpm. Check what rpm the ecu turns it on. Itll be close to where it should be.
[Modified by kinesistech, 9:16 AM 7/26/2002]
Old Jul 26, 2002 | 12:30 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: apex v-afc reading tach wrong (kinesistech)
so which is more accurate then?
i noticed that when my car was at 8000 RPM on the tach, my V-AFC registered 7660... i started going by tthe VAFC since its plugged directly into the ECU, so which is accurate?
Old Jul 26, 2002 | 12:32 AM
Default Re: apex v-afc reading tach wrong (dLo GSR)
I usually go with the stock tach for every day usage. My vafc is stashed to prevent its theft, but when Im tuning it (with the *** dyno) I use the vafc tach. As long as you have consistency, it really doesnt matter, they're not that far apart.
Old Jul 26, 2002 | 12:36 AM
Kamin's Avatar
i understand that most stock tachs are wrong
but not by no 1100 rpm's
he probably wired it incorrectly.
Old Jul 26, 2002 | 09:28 AM
mntdewred's Avatar
Default Re: apex v-afc reading tach wrong (KAMiN)
i'll recheck the wiring, but its odd how it was working fine then when i shut down and restarted, it began to read off.
bigedx
15
Apr 12, 2004 03:29 AM
HYREV2NR
Sep 11, 2003 06:21 PM
LeftCorner
Jan 6, 2003 03:54 PM
RAB
Dec 8, 2002 09:57 PM
BoostedGSRBubble
Jun 19, 2002 08:38 PM
