EK: ? for those w/Benen lower rear subframe brace
If you've installed a Benen lower rear subframe brace on your EK were you able to use the factory bolts? I took a quick look under the car and thought I might have to use ones that were a little longer so I went to go buy some and so far at Lowe's, Home Depot, Sears, and a Honda dealership I haven't been able to find any 12x1.5 bolts longer than stock.
I thought it would be easy but I'm striking out. If you used longer bolts where did you buy them? Thanks
I have bought these bolts (M12X1.5) from allens fasteners. I also collect from the junkyard when I go. Sometimes you can go to a good online Honda parts dealer and look through different random parts breakdowns until you find something that matches what you need.
JLEK
17
Jun 7, 2007 11:53 AM
