shifting problem
hey I have a 1998 Honda civic ex. I am having trouble with shifting because it is stuck in gear. It will not go into neutral. It feels hard too change gears and also i changed my clutch today so the clutch is good now. I thought that it would fix the problem but it did not. I also put the shift linkage together and it looks too be good. Also i was wondering if the peice where the 2 bolts go right under the shifter where the ball joint is if it is suppose too be put back a certain way or it does not matter? Any help will do this is my DD and i am bumming rides to work and school so plz help me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq »</TD></TR><TR><TD CLASS="quote">loosen the linkage..its on too tight.</TD></TR></TABLE>
where on the linkage do u mean its on too tight? This problem happened all of a sudden not right away.
http://www.hondaautomotivepart...4.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagnarX »</TD></TR><TR><TD CLASS="quote">where it meets the bottom of the shifter, if that is your problem i ran into the same thing, tightened it way too much.</TD></TR></TABLE>
can u let me know which one it is exactly there is a pic in the link up there. thank u in advance. Also, I forgot to mention that i can move my shifter around but it is still stuck in gear when i let go of the clutch and have the shifter in neutral.
HDFXST
Honda Civic (2001 - 2005)
12
Dec 26, 2006 05:59 PM
