Problems with civic
Old Jul 25, 2002 | 03:07 PM
DLB1994's Avatar
Default Problems with civic
i got a bulit ls/vtec with je pistons,pr3 head P&P,crower cams stage2 drag, crower valve springs with retainers,skunk2 intake manifold,aem cam gears,b16 oil pump,dc 4-1 header,p28 ecu with mugen program
fuel psi @50psi cam gear intake+2.5 ex+3
Denso spark plugs .44 gap
timing set at stock
the Problem is the start cutting power at 8500rpms it just started i was going to 9400rpms with no Problems but now i took the motor out and put new SS valves in and a new block its like it is missfireing or somthing or how the valves are adjusted what can make it do this
Old Jul 25, 2002 | 03:09 PM
Spade's Avatar
Default Re: Problems with civic (DLB1994)
Re-adjust valves.
boosted94gsr
Jun 14, 2014 10:13 PM
Nors
Mar 29, 2007 05:40 AM
Speed Infliction
Apr 19, 2006 11:32 AM
blaacksheep
May 6, 2005 03:16 AM
NiiS
41
Apr 7, 2003 07:36 PM
