primeing the oil pump
ok sometime this week i'll puting the dizzy in the car FINALLY!!!!
i've been thingking about this for a few days ,is there a way to prime the oil pump?
it's not going to be a dry start because i used three cans of oil soluable assembly lube .When i do the initial start up it'll be running straight 30
any suggestions
any suggestions
If it's out of the motor fill it full of assembly lube. Then when the motor turns it'll be primed instantly. IF it's already in the motor, your only choice is to crank the motor until you get oil pressure
if it is off the car as the Honda manual recommends take it apart and fill it with petroleum jelly as this allows for the pump to prime. This may sound silly but look it up.
i just did this unplug your dizzy turn the crank by hand like 10 times, turn by key a few times then plug in dizzy then hopefully it will start lol
READ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
besides i started it with no trouble and it"s back on the road
AK77
Sep 21, 2007 12:29 PM
Expletive!
Dec 22, 2005 07:02 PM
