Will having a quick release fail you in smog tests?
Old Sep 14, 2008 | 09:28 AM
EP sikwiidit's Avatar
Default Will having a quick release fail you in smog tests?
just tore up my wires for my srs/airbags and such... steering assembly column cost 400 +!!!!!
Old Sep 14, 2008 | 08:48 PM
HondatagirlPea's Avatar
From: Between the hills of Downtown LA and Pasadena
Default Re: Will having a quick release fail you in smog tests? (EP sikwiidit)
Wow.
anyways, it shouldnt cause a reason for failure
Old Sep 14, 2008 | 09:22 PM
Dartanian's Avatar
A smog test is not a safety inspection. As long as all the emissions stuff is there and your tailpipe emissions are within the acceptable range, you'll pass.
Old Sep 15, 2008 | 10:15 AM
Crazydave's Avatar
Default Re: Will having a quick release fail you in smog tests? (Dartanian)
I'm not sure if removal of air bags will cause a Check Engine light..
it WILL cause an SRS light though.
If you have a check engine light on.. yes it's AUTOMATIC failure in California
Old Sep 15, 2008 | 01:19 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EP sikwiidit &raquo;</TD></TR><TR><TD CLASS="quote">just tore up my wires for my srs/airbags and such... steering assembly column cost 400 +!!!!!</TD></TR></TABLE>
You won't fail smog for it, but you aren't legal.
YEAH!
May 6, 2011 10:03 AM
khmaitek
Jun 12, 2005 09:28 AM
Rocks
Oct 18, 2004 11:49 AM
bpowa
18
Sep 30, 2004 11:28 AM
GSR4door1
Apr 15, 2004 01:29 PM
