GSR Swap Problems......
Old Sep 14, 2008 | 05:32 AM
chris3385's Avatar
Default GSR Swap Problems......
Well I've searched and searched and checked everything I can pretty much check. Just wondering if anyone has any ideas..
I have a 92 Civic and a JDM GSR motor swap. Everything seems to be in working order. The motor will start if I shoot a shot of brake clean in the throttle body and run until that burns up but idles fast. I pulled the injectors out and they are squirting out fuel. Tried a brand new main relay, new fuel pump, have fuel pressure set at around 40psi. We tried messing around with the fuel pressure but still doesn't make a difference. Does anyone have any idea's? It seems as if the injectors just aren't squirting enough gas....
I have a brand new set of 550cc injectors I tried just for the hell of it and the car would start up and idle for about 40 seconds by itself then die.... Wouldn't start great but it would start and idle..
Any ideas or comments would be appreciated.
Thanks,
Chris
Old Oct 3, 2008 | 09:34 AM
Topsy_Kretts's Avatar
New User
Default Re: GSR Swap Problems...... (chris3385)
Hey wassup. What model civic r u running(EX?) and have u checked to make sure u have the proper ecu, and r u using a stock gsr intake manifold. chck to make sure ur throttle cable is properly adjusted, and if ur IAB is connected.
Old Oct 4, 2008 | 10:55 AM
slomofo's Avatar
GDD Member
Take out your spark plugs, pour a little bit of oil in each cylinder, put splugs back in, then try to start it.
If that doesn't work, come back and ask again.
Old Oct 5, 2008 | 07:11 PM
SoTexDC2's Avatar
Check your ignition timing, and be sure the TPS and MAP sensor's aren't reversed.
Old Oct 6, 2008 | 03:50 PM
raceready1320's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Take out your spark plugs, pour a little bit of oil in each cylinder, put splugs back in, then try to start it.
If that doesn't work, come back and ask again.</TD></TR></TABLE>
lol whats that suppose to do?!! that will just make the car smoke like a chu chu train!! lol
Old Oct 6, 2008 | 03:54 PM
Ryan#1's Avatar
Do NOT pour oil into your cylinders, unless of course you want fouled plugs.
How do your plugs look? What's condition is your ignition system in?
Old Oct 6, 2008 | 04:50 PM
SoTexDC2's Avatar
Default Re: (Ryan#1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceready1320 &raquo;</TD></TR><TR><TD CLASS="quote">
lol whats that suppose to do?!! that will just make the car smoke like a chu chu train!! lol </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan#1 &raquo;</TD></TR><TR><TD CLASS="quote">Do NOT pour oil into your cylinders, unless of course you want fouled plugs.</TD></TR></TABLE>
This is off topic, and I am not suggesting that this is the OP's problem!
Putting a few drops of oil into the combustion chamber is common practice when performing a compression check.
A few drops of oil will allow failing piston rings to seal better for a few strokes, giving you a higher compression reading, concluding that you should replace the rings. If the compression reading stays the same, then you know that your valve seals or head gasket could be leaking.
Old Oct 6, 2008 | 07:20 PM
turboaap's Avatar
Default Re: (SoTexDC2)
ok lets start with the check engine lite is it on and if it is what code do you have?
Old Oct 7, 2008 | 12:54 AM
im not the one to argue but i know whats rite and wrong! and pouring oil into your spark plug whole which is the combustion chamber is... thats just retarded! lol
Old Oct 7, 2008 | 12:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris3385 &raquo;</TD></TR><TR><TD CLASS="quote">Well I've searched and searched and checked everything I can pretty much check. Just wondering if anyone has any ideas..
Thanks,
Chris</TD></TR></TABLE>
check for spark... if its the original distributor the coil might have went bad... let me know if you get the problem fixed!
Old Oct 7, 2008 | 06:50 AM
sackdz's Avatar
Default Re: GSR Swap Problems...... (raceready1320)
And check plug gap.
Old Oct 7, 2008 | 11:43 AM
Default Re: GSR Swap Problems...... (sackdz)
could be a bad plug also... i just worked on a accord the other day put the new headgasket on... went to start it wouldnt turn over.. checked for spark it had spark on all four cylinders changed the plug and it started! especially the motor being jdm its prolly been sitting a while.. who knows how old those plugs are.. and if you could buy some new plug wires.. ive had a few plug wires from japan not work because there just so old
harley78
Dec 22, 2014 03:12 AM
Luke 91 ef
Jan 24, 2013 10:40 AM
93egSLEEPER
Jun 9, 2010 10:26 PM
ohsnapzafingcu
15
Jun 7, 2010 09:07 PM
chris3385
Oct 19, 2008 06:29 PM
