Can I use my B16 map to start a B18C?
Old Sep 13, 2008 | 02:28 PM
bosco500's Avatar
Default Can I use my B16 map to start a B18C?
I'm running a DTA standalone and toasted my B16. I bought a B18C5 and have put it in the car. I was told by the tuner that I could start the car and drive it onto the trailer to take it to get tuned. The problem is that the engine will start if I hold the throttle at about 10%. But if I let off the throttle, or give it any more than 10% the engine stalls. Does this sound right, or does it sound like some sort of sensor problem?
Is it ok to run on a B16 map or should I just push it on the trailer?
Thanks for any help
Old Sep 13, 2008 | 08:24 PM
98vtec's Avatar
moderator emeritus
Default Re: Can I use my B16 map to start a B18C? (bosco500)
your fine as long as your not trying to run 15:1 on pump gas It probably doesnt want to idle due to the injector differences.
just stay off the throttle trying to get it on. What does this setup consist of?
Old Sep 14, 2008 | 06:01 AM
bosco500's Avatar
Default Re: Can I use my B16 map to start a B18C? (98vtec)
Its a bone stock B18C. The previous motor was a built B16 with around 11.5:1 compression but was blown during its first race due to a small cut in one of the water hoses.
The DTA is model E48. I'm running a motorcraft coil system.
Thanks for the info
Modified by bosco500 at 10:15 AM 9/14/2008
Cian Mcloughlin
May 20, 2013 10:11 AM
Ravage70
Apr 29, 2007 09:22 PM
pissedoffsol
Apr 30, 2003 08:42 PM
